Question about Kenmore 98702 Stacked Washer/Dryer
My stackable washer/dryer laundry center no longer allows adequate flow of hot water. It was fine one load, and hasn't worked since. Now it just trickles hot water into the washer. Any ideas?
    Brigadier General:
  • 6,277 Answers
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose. If after turning the tap back on there is no improvement, the problem is symptomatic of a malfunctioning hot water control valve. Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Posted on Apr 07, 2011
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
Frigidaire gallery series washer dryer stackable unit will not fill all the way
Hi Friend, this is Z. Thank you for your inquiry!
I understand that your Frigidaire laundry center will not completely fill. Here are a few troubleshooting tips that may help you get to the root cause:
First, disconnect power from your washer. It is good to wait roughly ten minutes and then turn on your laundry center? Did the issue persist? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, your laundry center may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
May 25, 2014 | Frigidaire Washing Machines
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Seperate washer and dryer
Unfortunately, your washer and dryer are part of a "laundry center". Which means, the two together are one system. They cannot be separated. You can still use the dryer, obviously. Have you considered fixing the washer?
Jun 21, 2007 | Maytag LSE7806A Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
