Question about Cycling
I bought my partner a vertigo suspension bike but I cannot get the front wheel to fit into the brakes? Can you help?
    Brigadier General:
  • 8,546 Answers
Http://www.jimlangley.net/wrench/removerearwheel.html
It applies to both wheels. You have to open up the brake.
Posted on Apr 07, 2011
Front forks on a 1987 Honda Goldwing motorcycle how to change them
Place bike on center stand.
Jack the front of the bike to raise the front wheel off the ground. Be careful!!!
Remove the front wheel.
Remove the front fender and cross brace.
Disconnect the brake calipers from the forks.
Remove the air connections from the fork tops.
Loosen the fork leg clamp bolts on the triple tree.
Slide each leg out of the bike. Twisting while pulling often helps.
This can also be done without removing the front wheel but you will have to elevate the front of the bike another foot or so - just disconnect the air fittings and brake calipers, loosen the clamp bolts and drop the whole front assembly.
Jul 22, 2014 | Motorcycles
Pulsar 150 cc DTSi bike. Some sort of sound is coming infront of my bike when it runs in the rough roads. Kind of sound like some part are moving infront of my bike. What is this noise ?
This could be a number of things causing this problem.
The best thing to do is put the bike up on a bike stand so that the front is of the ground. Then pull and push the front forks to check there is not wear in the steering neck bushes.
Also check your wheel bearings that they are not rumbling when you spin the front wheel.
Check these 2 areas and let me know how you get on.
Thanks
Jason
Sep 27, 2011 | 2007 Bajaj Pulsar 150
My car vibrate at 100-120km/hr i have bought new tires and done the wheel balncing but it still vibrate and whenever i tried to apply the break at this speed it vibrate serously. it's a 2001 mazda mpv
This is due to poor settings of the wheel bearings,tyres,- check balancing once again, wheel drums/ brake pads,suspension , joints and steering.
In all the entire front suspension must be checked, the WHELL ALIGNMENT must be checked with precision and each of the wheels must be checked for damage on hub, axle or chassis.
Aug 08, 2011 | 2001 Mazda MPV
How many many it is
I hope this is what you were looking for-
General information Model: Hero Honda Glamour Year: 2006 Category: Sport Rating: 58.9 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 124.70 ccm (7.61 cubic inches) Engine type: Single cylinder, four-stroke Power: 9.00 HP (6.6 kW)) @ 7000 RPM Top speed: 85.0 km/h (52.8 mph) Gearbox: 4-speed Transmission type,
final drive:
Chain Chassis, suspension, brakes and wheels Frame type: Tubular double cradle type Front brakes: Expanding brake (drum brake). Optional disk brake Rear brakes: Expanding brake (drum brake) Physical measures and capacities Other specifications Starter: Kick Further information Parts and accessories Check out parts and accessories from our other partners. Ask questions Join the 06 Hero Honda Glamour discussion group. Insurance, loans, tests Check out insurance here. Search the web for dealers, loan costs, tests, customizing, etc. Related bikes List related bikes for comparison of specs
Mar 02, 2011 | 2006 Hero Honda Glamour
How do you change the front shock?
to change the front suspension, its just a matter of taking off a few peices
  1. you need to take off the front wheel.
  2. remove the brakes
  3. take off the handlebar and the connector
  4. at the front of the frame of you bike there should be some gigantic nuts(as in bolts and nuts[screw]) loosen until you front suspension can be pulled off.
this is for a majority of bikes to install the new suspension just reverse the process
Feb 23, 2011 | Cannondale Scalpel Carbon 2
Actually i dont want any solutions;i just want to know about yamaha rd 350
Model: Yamaha RD 350 Year: 1986 Category: Classic Rating: 76.9 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 347.00 ccm (21.17 cubic inches) Engine type: Twin, two-stroke Power: 63.00 HP (46.0 kW)) @ 9000 RPM Top speed: 190.0 km/h (118.1 mph) Compression: 6.0:1 Bore x stroke: 64.0 x 54.0 mm (2.5 x 2.1 inches) Fuel control: Membrane & power valve Cooling system: Liquid Gearbox: 6-speed Transmission type,
final drive:
Chain Chassis, suspension, brakes and wheels Front tyre dimensions: 190/90-18 Rear tyre dimensions: 110/80-18 Front brakes: Dual disc Rear brakes: Single disc Physical measures and capacities Weight incl. oil, gas, etc: 170.0 kg (374.8 pounds) Fuel capacity: 20.00 litres (5.28 gallons) Other specifications Further information Parts and accessories Our partner CMSNL ships low cost OEM motorcycle partsimage-1696787-10826297 to Australia, Austria, Bahamas, Belgium, Canada, China, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hong Kong, Hungary, Iceland, India, Ireland, Italy, Japan, Kuwait, Latvia, Lithuania, Luxembourg, Macedonia, Malta, Montenegro, The Netherlands, New Zealand, Norway, Poland, Portugal, Serbia, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Ukraine, United Kingdom, The United States and more. Or check out parts and accessories from our other partners.
Dec 29, 2010 | 1986 Yamaha RD 350
Whats makes the front end shake if you have replaced the brakes, roders, caliperes, and everything else that has to do with the brakes
Front end vibration has little to do with the brake system on the car. Yes you can get some "brake shudder" when you apply the brakes when you have worn brake rotors or when the rotors are not properly aligned on the hubs. However from what you have said you do not have this problem.
Front end vibrations can be caused by a number of factors some of which are listed below:
1. Front wheels out of balance. (Common problem on many vehicles).
When were the front wheels last balanced? You will get vibrations through the car and the steering wheel at particular speeds. This will/could also occur if the wheel rims have been distorted as a result of abuse.
As a first step the wheels should be balanced and then retest the vehicle for the problem.
It can be impossible to properly balance some wheels because the tires fitted to the rims are of poor quality and contain heavy spots that are impossible to correct with wheel balance weights. If you have cheap tires fitted on the wheel rims then it may be impossible to balance the wheels properly because of the imperfections in the tyre. In that case you will have a permanent wheel vibration problem which will only be rectified by fitting good quality tires and re-balancing the front wheels.
If aftermarket wheel rims have been fitted to the vehicle this can also be a source of vibration. Some wheels on the market are poor quality and can be slightly out of round and/or have heavy spots in them which can be impossible to correct when you fit the tires and have the wheels balanced. Many people think a cheap set of "blingy" aftermarket wheels are a great buy but if they are poorly built (as is often the case) you will usually have no end of problems.
2. The front wheel alignment could be out.
If the front wheels have not been aligned in the past 12 months they probably will be out of alignment. When you have re-balanced the front wheels you should have the front wheel alignment checked and then re-aligned if it is out. However if their are worn suspension components (see 4) found on the car which need to be replaced, this repair needs to be done before the front wheels are re-aligned.
3. Worn out wheel bearings in the front hubs.
If your front wheel bearings are badly worn you can get a vibration through the steering wheel. If the vehicle has done about 100000 miles or more on the front wheel bearings they should be replaced. In any event , any competent mechanic can jack up the front of the car and check for excess play in the wheel bearings.
4. Worn out suspension components. The front end of the car should be checked for badly worn suspension and steering components.
I would recommend you take the vehicle to a competent mechanic or a suspension specialist in your area and have them check the vehicle for you.
I hope this helps.
Dec 12, 2010 | 1999 Chevrolet Suburban
Help with the front brakes, jus bought the bike and need to re fit a new disk and pads into the calliper, as much info on this would be appreciated, alternativly if a genaral manual on the yamaha tw 125 02...
Hi glen
Replacing the disk is quite easy. Remove odometer cable, Disassembly front wheel, then screw out 6 bolts of disk. Replace disk+ fix it with bolts. Before you put back front wheel replace the old brake pads. because the new disk will be thicker, and you will be not able to slide it beetween brake pads.
Replacing the brake pads- its better to see..Here is the manual:
http://rapidshare.com/files/405700960/tw125-2002.zip
kind regs
Feb 19, 2010 | 2002 Yamaha TW 125
Saab 93 - noisy when going over bumps on the road.
Have you tried driving over a bump whilst also applying the brakes? (Right foot on gas, left gently on brake - with no one behind you!) If the noise goes away, then it could be the brake pads that are not fitted correctly. Only posting this, as this just happened to mine...the mechanic took it over bumps and noise was there. Applied brakes whilst going over bump, noise went away. Replaced badly fitted rear pads (had been bodged by another garage) and the problem was solved.
Apr 23, 2009 | 2004 Saab 9-3
MOT Test
a) Sitting on machine check:1. All controls switches and horn 2. Front suspension forks handlebars and head bearings. b) At the front of the machine check: 1. Front lights and indicators 2. Front brake master cylinder (if fitted) c) Place the machine on its stand and raise front wheel check: 1. Steering, front forks and head bearings 2. Front brake and wheel bearings 3. Wheel and tyre condition. d) Lower front wheel and go to right side of vehicle and check: 1. Frame, VIN, seat and foot rest 2. Exhaust system 3. Final drive (if fitted to RHS of machine) 4. Rear wheel, tyre and brake e) Raise the rear wheel and check: 1. Rear wheel, rear brake/components and tyre condition. 2. Rear suspension and final drive f) At the rear check: 1. Rear position lamp(s)/stop lamp(s)/reflectors and indicators. 2. Rear suspension. 3. Registration Plate g) On the left of the machine check: 1. Frame and foot rest 2. Exhaust system 3. Final drive (if fitted to LHS of machine) 4. Rear wheel, tyre and brake. h) At the front of the machine check: 1. Wheel alignment 2. Headlamp aim 3. Brake performance,,,
Nov 10, 2008 | 2003 Hyosung GT 600 Comet
Cycling Logo
99 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
