SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: need manual for Troy Bilt lawn mower 12ai867q011
Hi and welcome to FixYa. I am Kelly. You will need both your model and serial number but you can get it online directly from Troy-Bilt here:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1
Just enter your model and serial number and download the manual.
Thanks for choosing FixYa.
Kelly
Testimonial: "Thanks"
