Question about KDS K-726MWB Monitor
How is the power to the monitor supplied? via the computer or via an electrcally plug - I don't see were the connection is on the monitor
  • 53 Answers
The monitor should have come with two cords. One the power cable which will have an electrical plug on one end that is plugged into a wall jack and the other should be one like this.The other end of the electrical plug should plugin somewhere on the bottom of the monitor.
There is another cable that looks like this which is known as a vga cable. Your monitor may take a DVI connector which has a white end and is a larger plug. This will plugin to the monitor and will also plugin to your computer. The place it plugs into the monitor should also be on the bottom of the monitor.
These cables will only fit in one way so you really can't mess anything up. Also the cable between the monitor and the tower are interchangeable it doesn't matter which side you plugin either way will work.
Posted on Apr 07, 2011
Do I need both cables for windows machine or can the USB connected to the machine and the mini dp plugged into the monitor work by itself
Is this an external monitor cable? Where the monitor cable that connects to the computer has two USB cables attached at one end?
If so, no. You do not need to plug both ends in. If one is powering the monitor fine and you see no performance problem occurring with the monitor you are OK to plug in just one.
The extra USB end connected to the cable is for additional power supply. If for some reason the machine you are plugging into does not supply enough power to the external monitor you would plug the second end it to the machine and boost the power to the monitor.
Hope that helps.
Oct 20, 2015 | Computers & Internet
Camcorder won't turn on
is this camcorder battery dead, is the cell battery dead ,
have connected camcorder to power cable and it is still dead I need to know if it is receiving any power supply or just the power supplied from your pc
Apr 14, 2014 | Toshiba Camileo X400 Camcorder -...
Power option does not work when setting it to turn off monitor
The monitor has a separate power supply, 1 AC plug for the computer, 1 fro the monitor. The Power Options only apply to the Computer, your monitor will not shut off via the computer power options.
May 24, 2013 | Systemax Ascent RTS A14 (980796) PC...
I recently got a TCO'03 Display at a yard sale..it has a power cord but where do i plug in into my computer?
You don't plug the power cord into the computer. You plug the power cord into an AC outlet. You need a VGA cord for connecting the monitor to the computer. Walmart, K-Mart, Radio Shack, Staples, OfficeMax, and any of many other stores should have the cable.
Aug 04, 2011 | Acer X193W LCD Monitor
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
I tried turning on my monitor and it wouldn't turn on. I checked the power cord and everything was connected correctly. Any Idea;s?
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Feb 10, 2010 | Mag Innovision InnoVision LT765 17" Flat...
My laptops screen does not come on even though the unit powers up,i have tried another screen,and tried using external monitor,neither worked,the lights by power button also don;t light.
Did you check the power supply? They go bad and if you get no power, nothing else will work. You can check the power supply by plugging the unit into an outlet and then using a volt-ohm meter measuring the voltage at the cylinder which normally plugs into the computer. If there is no voltage (DC) present, then the supply is bad. You can get a replacement online or at the place you purchased the unit.
Feb 01, 2010 | Computers & Internet
Lighting came into my computer via the ethernet cable. can this be fixed I also think it took out my power supply un it. It is a gateway 500c.
If only power supply's affected, then change the SMPS with a compatible one of the same rating. But first check the monitor by connecting to the mains power supply with the video chord not attached to anything. if the monitor displays "no videos" signal, then the monitor is OK cange the SMPS of the CPU and check UPS & spike boards fuses, otherwise commect to main power supply pluf(Wall 3-pin outlet socket)......sodeep
Jun 09, 2009 | Gateway (4000274) Motherboard
Acer 1711 monitor won't power up
power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
Feb 18, 2008 | Gateway FPD2275W LCD Monitor
PS/2 power supply connection
You seem to have an oddball monitor if what you describe is correct. The power supply to a monitor[Display Screen is that what you mean?] is either direct to main power- in which case the power cord is either built in with a power plug for wall socket, or has a socket on the back for a separate main power cord. Or is powered from a low voltage converter that delivers low volts usually via a coaxial plug like this illustration PS2 connection does dot come into the equation as far as I know unless you have got hold of something unusual. Tell you what take a shot of the back of the monitor and lets have a look see mean while here's is a shot of a typical low voltage power supply available anywhere.
May 26, 2007 | View and View Technologies VNV AquaView...
KDS K-726MWB Monitor Logo
82 people viewed this question
Top KDS Computers & Internet Experts
daibras
Level 1 Expert
Cleverer2
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
