When i was hooking it up it made a big spark and now it smells like it is fryed
Stand in water and hold onto exposed wires then power up the unit you ******* ********
Posted on Jun 20, 2009
  • skinkstatu Jun 20, 2009
    good i hope it never works again
  • 682 Answers
Please always turn off your system befor any connection----clean contact points of socket(the place where you put your jack)with any contact cleaner-connect your cable again and turn power on and try in low volume and increase the volume gradually until you get good sound-----if all above failed you will have hardware problem inside your receiver and can fix through field technician
Posted on Aug 06, 2008
My jbl eon 15 g2 smell like burnt and everything works but the big speaker
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
Jan 18, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
I just hooked up my amp and it shot sparks out of it and stopped playen.
did you ground it first before connecting live? it sounds like you have fried your amp. If your amp is fried which is very likely if sparks came out of it, its no good and needs repairing or shot of.
Feb 25, 2011 | Pioneer Car Audio & Video
I tried to jump start my jeep with a electric golf cart. It made a big spark and now all it will do is turn over. Could this have fried the computer system? All the lights, windows, dash, and etc.. are...
Depends on how many batteries were in series when you hooked it up. If you supplied the full possible 36 volts, there is no telling what you fried.
Start by checking the fusible links on the fire wall and all fuses.
Lots of luck
Apr 22, 2010 | 2004 Jeep Grand Cherokee
STARTER SHORTED OUT
main wire to the big bolt, little wire to the little bolt. dont do this with the battery in becuase you could fry some wires. if you have already fried the wires then there should be a fusible link just off the battery
Sep 17, 2009 | BMW 325 Cars & Trucks
Kenmore fridge started having sparks and has an unpleasant smell
the compressor is asealed unit and wont cause any smell but it does have a push on starter on the compressor pins under the cover (most likely cause)
Possible other faults are defrost element or defrost timer
Jul 27, 2009 | Refrigerators
1996tbird no fire
Loan a free computer scanner from one of the big auto chains and hook it up in the plug under the glove compartment. Write down any error codes and either read them in the manual or search for them on the web. Been there. Good luck.
Jul 07, 2008 | 1996 Ford Thunderbird LX
 Grubhead
Grubhead
