How do I replace power jack in my Toshiba A215-S5822 laptop. Do I only need to remove the Keyboard to expose the jack?
  • 6,993 Answers
The answer is no. You have to take the whole laptop apart including the keyboard in order to conveniently replace the power jack. If you don't take the whole laptop apart, there won't be enough space the replace the power jack.
Remove the internal battery pack from your laptop. Flip the laptop over and locate the release button for the battery pack. Hold the button in to slide the battery pack free. It is important that you remove the internal battery pack as well as unplug the power cord from the wall outlet to prevent risk of shock while working inside the laptop.
Unscrew all of the screws on the underside of your laptop. There should be one at each corner and then one or two screws that hold the hard drive cover in place, like wise that of the memory (RAM). Once the screws are removed, take out your computer's hard drive and memory (RAM).
Locate the two screws at the back of the computer that hold the laptop screen's hinges in place. Once these two screws are removed, gently pull up on the screen until you clear the silver pegs from the holes in the laptop's body. Two wires lead from the screen into the computer, so ensure you do not pull so hard that you disconnect them. Carefully set the laptop screen aside so it does not get damaged while you work inside the computer.
Separate the two halves of the laptop's body to expose the computer's internal components. Flip the keyboard on its face, making sure not to disconnect the keyboard's connector. Underneath the keyboard will be a metal plate that covers the computer's motherboard. Unscrew the screws that hold this plate in place and set it aside.
Locate the DC jack for the laptop. Using your tweezers, remove the old DC jack. Identify the slot in the motherboard that the old DC jack came out of. If the DC jack was loose before you removed it, there will be a small slot at the base of the opening in the back of the computer that the DC jack pops into. Using the tweezers again, slide the new DC jack into this slot until you hear a clicking sound. To hold it in place you can solder the new jack to the motherboard, or simply superglue it in place. Don't use too much superglue or you will risk losing the ability for the jack to conduct electricity.
I wish you good luck as your replace your laptop power jack.
Take care.
Posted on Apr 07, 2011
  • 734 Answers
Hi There,
Toshiba does not publish Service Guides for us lowly ones of the General Population. You can go to the link below and get as far as removing the wireless card, which may or may not expose the jack for replacement.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/remove-wireless-card.htm
After that it's going to be a matter of carefully removing what you have to to get to the jack. Other similar laptop guides at irisvista may hold the key for you. I've used that method and found that using the guide for the model just before or after got me close enough to the order of disassembly I could get the job done.
Be careful, take your time, amd make a grid of what goes where on paper and you should be able to get the job done.
Regards,
Selk
    Sergeant:
    Champion:
  • 286 Answers
Strewth M8 you have a long way to go on this one. I would suggest you dont touch it at all. You have completely open the whole computer to get to it. I would suggest you go to a dealer and save some money.
I did not ask for advise I asked how to fix the power jack? Thanks
My friend Im here to please. But if i was you you i wouldnt touch it. I have two. They are Buggers to put back together.
Apr 07, 2011 | Toshiba Satellite A215-S5822 Laptop
How do i go about changing the dc power jack? I have found sources for the part.
Your next step is to download the service manual from Toshiba. This will give you detailed instructions for disassembling your laptop. Luckily for you replacing the jack does not require soldering, it plugs in. The part can be found HERE for less than $5.00
Apr 06, 2011 | Toshiba Satellite A215-S5822 Laptop
How to recover a toshiba a215-s5822 without a cd recovery disk
check here hopefully you can find a copy of the recovery disk http://www.user-guides.co.uk/Toshiba/ToshibaCDDownloads.asp?keywords=Toshiba%20Download%20Manual%20Drivers%20CD%20ISO%20PDF
Aug 27, 2010 | Toshiba Satellite A215-S5822 Laptop
Can not be turned on
We will see if the problem is due to the static charge accumulated on the laptop. Disconnect the power cable from the laptop and also take out the battery. Also, disconnect all the external devices attached to the laptop e.g. external mouse, keyboard, printer. Now keep on holding down the power button on the laptop for the next 30 seconds. Put the battery back and plug the power cable. Now try turning on the laptop and let me know if it works. Thanks!
Dec 26, 2009 | Toshiba Satellite A215-S5822 Laptop
The laptop wont boot up.
remove battery and test it if doesnt work try to test it by another power adapter.
Aug 05, 2009 | Toshiba Satellite A215-S5822 Laptop
Keyboard
First try to check that the keyboard connection to the motherboard is still solid & that the key is depressing as it should. If all is connected there may be a hardware fault on the keyboard - if so I can get you a price on a replacement.
May 11, 2009 | Toshiba Satellite A215-S5822 Laptop
Toshiba A215-S7407 Bios is asking for a password
The BIOS password is on a chip on that motherboard... it is FirmWare... Integrated into the laptops Motherboard, You Will Need To Replace The Motherboard To Be Able To Have A Working Laptop...
Feb 02, 2009 | Toshiba Satellite A215-S5822 Laptop
XP Drivers for Toshiba A215 s5822
Welcome to FIXYA
you can look on 2 different websites for the driver these are good and trusted websites
drivers.com , or driversupdate.org
i hope these help you out have a good day:)
Jul 15, 2008 | Toshiba Satellite A215-S5822 Laptop
Reset
It will be on the main board of laptop. You need to open the base and keyboard of laptop. Careful
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
