Question about Xerox DocuColor 12 Printer
Oil Mark How to reduce the oil mark on paper when using heavy weight or extra heavy weight setting. Lot of oil line on the paper surface.
  • desmond58 Aug 12, 2008
    is that the one with the material something like sponch?
    Habit-Forming:
  • 75 Answers
Assuming you do not have any machine problem, you could try what I do on some jobs............I take a lint free soft cloth and buff the oil residue. Works almost every time and does not take very long.
Posted on May 21, 2009
Posted on Aug 24, 2008
  • 79 Answers
Hi friend just u clean oil blade and oil assembly... if u have new blade just change that.. this only sollution for this problem..
Posted on Aug 12, 2008
  • jai kumar
    jai kumar Aug 12, 2008
    thats name oil wick... oil blade touching in small orange and black roller.. its a rough rubber blade.. u clened wick also...
Hydraulic tank says use mobile one 15-50 the X Mark store told me to use ex mark hydraulic fluid. Will they mix?
They will mix but unless the Ex-Mark oil is synthetic is it not the same quality of oil as the Mobil 1. Check the weight of the Ex-Mark also.
I'd use what the manufacturer suggests unless I was in a bind.
Jan 15, 2018 | Garden
Hi can u pls assist me with the timing marks for this car chevy aveo 1.5 engine 8 valve 2006 model hatch back pls urgently & also head bolts torque setting
Your timing marks should be on the belt. There are two single lines and one double line across the surface of the belt. Each of the single lines line up with the cam shaft and the balance shaft drive gears. The double line lines up with the crank gear. If I remember right, there is a small mark on the oil pump housing that the crank mark lines up with and the cam mark is straight up and there are 2 other marks on the cam gear that line up with the head.
Jun 05, 2015 | 2006 Chevrolet Aveo
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
Stretchmark in my tummy for giving birth..
Hello, Hope this help, and con grads on your recent child!! Not all women get stomach stretch marks because they're having a baby. Most just get them because they suddenly became fat. When excessive fat is stored on the abdomen, these unpleasant-looking marks appear. Obese people often encounter this cosmetic dilemma. To lessen or even avoid getting stretch marks, make sure you avoid sudden weight gain. Maintain a healthy, low-fat diet and avoid fatty and calorie-filled foods (Learn how to lower fat in your diet). Products rich in Vitamin E, C silica and zinc are more advisable, since these keep skin healthy. Don't overeat (Tips on how to get rid of overeating), and avoid sleeping after meals. Drinking plenty of water is also important, since it keeps the skin hydrated. Can You Type? Earn $396/Day Working From Home? You should also exercise. Exercise tones down the body, removing all the unwanted, excess fat and preventing the appearance of these marks. If you've already gained weight, and the stretch marks have already started appearing on your abdomen, try to lose some weight in a slow, steady and sustainable pace. Losing weight suddenly can also lead to stretch marks. Don't Eat For Two If you're expecting a baby, then stomach stretch marks are something you must expect to appear. After all, not only is a child growing inside you, which means a drastic change in your weight. Even so, it's not true that you must "eat for two". Your appetite will increase during several points in your pregnancy, but you do not necessarily have to ingest more servings just to "feed" your baby. This just creates more fat and more stretch marks. Moms must ingest extra calories for their infant, at least 500 calories everyday, but the trick is to get these from nutritious foods, and not fatty ones. This allows you to shed off the fat easily, after you've given birth. Start Early Stretch marks are unavoidable for pregnant women, but thankfully, there are ways how they can reduce these marks. Even when they haven't given birth yet, they can do simple tricks to keep their skin healthy and make it more elastic. One simple tactic is to massage their skin everyday, using a massage glove or a moisturizer. This helps new tissue to grow and also improves circulation. Although it's not proven yet that creams, lotions and moisturizers can prevent stomach stretch marks from appearing, there is evidence that these can help lessen the effects of skin stretching, since they keep the skin supple and maintain elasticity. As long as they're frequently and properly used, unpleasant stretch marks won't be very noticeable in the future. When choosing creams or moisturizers to use on stretch marks, find some that contain vitamin A or vitamin E. Natural ones made from plant extracts and creams that have alpha hydroxy acids or AHAs are also very helpful. Check first with your ob-gyne if the product you use for removing the marks is effective and advisable. Reducing Stomach Stretch Marks With Effective Products You can't totally eliminate stomach stretch marks once they show, but there are ways on how to reduce their appearance on your skin. There are effective skin products that helps minimize these scars. Here are a few popular examples: Castor Oil - Rub it all over your hips and stomach. Lavender- Massage it all over your hips, stomach and breasts. Warm Olive Oil - It relaxes the person to a great extent and improves blood circulation. Calendula Oil - This herb is useful for medicinal and cooking purposes. Massage it all over your abdomen gently, to improve blood circulation and reduce the marks. Chamomile-Lavender- Almond Mix - Take half a teaspoon of chamomile oil and lavender oil and mix into a small portion of almond oil to treat the marks. Flaxseed Oil - Useful for stomach as well as hip stretch marks. Cod Liver Oil- Use the same way as flaxseed oil. Cocoa butter- Made from fat acquired from cocoa beans, this light-yellow mixture is very helpful in reducing stretch marks. Egg whites or egg powder - It sounds strange, but many people find these effective. Natural products like these bring back your skin's suppleness and health, but they don't harm your child. When used regularly, they help your marks fade in time, until they're barely visible. Opt For Surgery Once you've had your baby, and you've gone past the first few months of maternity, you can now consider a faster, but more effective way of removing stretch marks from your body: surgery. Modern technology now allows you to undergo a procedure that will help lighten stretch marks efficiently. One popular method is through laser surgery. Depending on the stretch marks' color and gravity, the surgeon will decide which type of laser procedure suits your condition best. Different kinds of lasers are used. One kind of laser can stimulate pigment-making cells' production, found in already-faded marks. Another can reduce dark stretch marks. Some laser also restore the elasticity of the skin and stimulate collagen production in depressed stretch marks. Consult a qualified plastic surgeon first, and see if you're fit to undergo laser surgery. He will recommend different options for you. You should also keep in mind that this can be costly. Laser surgery can cost you a few thousand dollars. Just because you're a mommy now doesn't mean you have to forget about your **** and flawless figure. take away all those nasty blemishes on your stomach through these stretch mark removing methods. You'll soon be able to sport that toned and **** abdomen of yours. If you enjoyed reading this article, you should read how to lose weight after childbirth too.
Sep 01, 2011 | Health & Beauty
Head gasket change
to remove head gasket first take off the valve cover and locate head bolts .make sure one is not broken . then remove timming belt cover and set engine to top dead center by the mark on the crank pulleyengine drive belt will also need to be removed.loosen timming belt tension ,mark belt osision and slide belt from camshaft gear .sometimes its easier to remove the gear.disconect fuel lines ,exuat pipe from manifold ,and sensor wires ,sparkplug wires and any other vacum lines wires ,ect ....that are conected the the cylinder head. before removel disconnect battery and drain cooling system. remove the head bolts ,inside and work to the outside in a circle.may need to pry head from the engine block careful .reinspect to make sure all hoses and wire ,lines are not still attached..always seems to be one thing that will still be attached..after head is removed ,you should be able to see where the gasket is damaged. clean all mating surfaces off engine block and head toinspect for cracks and damage.make it extra clean....razor blade scraper, sand paper ,brakecleaner and lots of shop towels. that is the most important to have clean surface ...install new gasket and reinstall head bolts to the proper tourque specs. parts guy can tell you if you dont know. when the head bolts are tight, this is a good time to drain oil and filter and after repair is finished install new 50/50 coolant. good luck with your repair
Feb 16, 2011 | 1994 Ford Escort
What kind of oil do i use in my 2005 sebring touring
Hello rockanddance: My name is Roger and I will help you. Use 5w30 weight oil in your engine. Unless the oil cap says to use 5w20 weight oil. Should you need further help please just ask. Please rate your answer. This way I know it was useful. Thank You for using Fix Ya. Roger
Mar 29, 2010 | 1998 Lincoln Mark VIII
What causes clattering or clicking sound when you start it up early in the morning on a 1993 lincoln mark viii?
Sounds like lack of lubrication on the camshaft, especially if the sound goes away after 10 sec. or so.
If you are on a cold climate, shift to a lighter oil weight, such as 5W-30. Other option is to use commonly available oil superlubricants/ additives. Origin of problem is that oil gets drained down during the night, camshaft gets dried up, and on first start in the morning, oil pump works hard to pump the heavy oil to the top of the engine. On hotter climates, some oil stays attached to the camshaft and valve lifters.
Dec 26, 2009 | 1993 Lincoln Mark VIII
Black ink mark
try this......run a card with heavy matte paper using 'regular settings'.....see if the extra black is gone then
Oct 04, 2008 | Epson Printer
Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Sep 23, 2007 | HP Photosmart 3310 Printer
Xerox DocuColor 12 Printer Logo
109 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
