Question about LG 22" FLATRON LCD Monitor
My screen turned greensih when I accidentally touched the bottom right where the settinsg are. This ahppened once before and I was told how to fix it but didn't save the directions. Can you tell me how to "reset" it?
    Sergeant:
    Champion:
  • 286 Answers
Ok, You have to find th settings button, which is close to where you touched it..LOL... The find the colour reset and go from there im sure you will remember it all after that.
Hope this helps.
Posted on Apr 07, 2011
My tablet is froze on talk back. Unable to turnoff the talk back nor can I turn off tablet.
Android? Press and hold the Power Button and the Volume Up button until you see the Android logo.
iPad? Press and hold Power button and the Home button until you see the Apple logo.
/or
There are two ways to unlock your device once TalkBack is turned on:
Two-finger swipe up from the bottom of the lock screen. ...
Explore by touch to find the Unlock button at the bottom middle of the screen, then double-tap.
Turn on TalkBack - Android Accessibility Help - Google Support
https://support.google.com/accessibility/android/answer/6007100?hl=en
Jun 17, 2017 | Cameras
Dear Guru, I have a problem with my garmin 265w device I did everything that you said for a hard reset, but when I turned it back on and pressed the right bottom corner, it didn't reset, and the...
You need to press and hold the bottom right corner of the touch screen BEFORE you turn the power on. You only stop pressing when the reset menu appears.
Jul 12, 2011 | GPS
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
Setting the time on the PU910222003 Puma ladies watch.
The process may be less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
Ipod touch 2g very dim
Follow these instructions to brighten the screen.
1...Turn on I Pod
2...Slide to unlock
3...Touch "Settings"
4. ..Touch "Brightness"
5...Move the "Slider Bar button" to the Right to Brighten the Screen, Left to lower the Brightness, once you have the desired brightness on the screen you will then touch the "Settings" tag at the left corner of the Ipod to take you back to the "Settings" screen.
6.Push the button on the screen at the bottom of the player to return to the Main Screen and you are finished.
Please rate me for this Free Answer.
Dec 19, 2010 | Apple iPod touch
Tom tom one no sound
Make sure it was not accidentally MUTED
On a map display touch the map once
Then select the spanner / wrench icon and touch it once
Now use the right arrow to scroll until you see the speaker icon. make sure it is not muted.
If you keep using the right arrow you will also find a screen that has the volume control itself, make sure it is not just turned down.
Aug 30, 2009 | Tomtom ONE GPS Receiver
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
My DS touch screen flashes once when the power switch is flipped, then turns off.
when the ds turn off right after being powered on, that generally would mean the that the ribbon cable that goes from the top to the bottom is either disconnected, or ripped. thats like a $15-$20 fix or so when u get the parts.
Dec 27, 2007 | Nintendo DS Console
SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, criszhill@yahoo.com
Jul 19, 2007 | Sharp Wizard OZ-590A
LG 22" FLATRON LCD Monitor Logo
70 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
