Question about Toro Lawn Boy Self Propelled CARB Walk Power Mower
Lawn boy mod.10684 self prop. will not pull itself , adjusted cable but no help,what can I do
How do adjust for Speed stability on Lawn-Boy mower. It hunts up and down.
Speed control for motor is controlled by an automatic governor, so there isn't any adjustments. Surging is caused by an air leak. Has the air filter been changed? Spray card cleaner around that side of the engine to find the air leak. Does it have a choke adjustment? Make and model would be handy in answering this question!
Oct 18, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Pull cord on john deere 190cc 6.75 hp
The housing might be riveted to the engine housing and might need to come off together. Hope this helps!
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I can push the handle all the way in, but I get very little speed from the mower.
Your throttle cable likely needs adjusting.
It should be fastened on the engine with a screw. Loosen that screw and adjust while engine is running then tighten Keep fingers away from underneath while engine is running.
Oct 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Jun 22, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Toro Lawn Boy Self Propelled CARB Walk Power Mower Logo
290 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
