Question about Iomega 34579 1 TB USB 20 Hard Drive
I have a GDHDU and have lost the part that you actually plug into your usb bit of the computer and then back to the external hard drive. Is there anywhere that i can get this spare part?
  • 53 Answers
If you are talking about the cord that goes from the external drive to the computer then yes. Go to your nearest computer store and ask them for a printer cable. Otherwise known as a USB A male to USB B male cable. I say printer cable because its the same as the standard printer cable. Most help their will understand right away what you mean when you ask for a printer cable.
Also get the silver not the gold tipped. Its cheaper and there really isn't any difference between the two.
Posted on Apr 07, 2011
Lost power supply. Can I order one? What is voltage output?
Posted on Aug 09, 2011
Lost install cd software bundle
Hard drives usually self install. Unplug the driver and switch it of so it is disconnected from the USB. restart your computer. turn the power back on for the drive and Plug the USB lead back in to the computer (When started up). Windows should install the driver automatically. This will take about a minute or two.
Jan 26, 2014 | Maxtor OneTouch 4 500GB External USB 2.0...
How to take apart a gdhdu hard drive
Not a good idea. With the correct screw drivers it can be done. WHY? there is nothing to fix, and most likely it will be useless when you finish.
Apr 18, 2013 | Iomega GDHDU2 2tb Select Desktop Hard...
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
Dear All, I have external HDD Maxwell 1T 2.0USB. It was working properly but now it is asking for format. What can be a problem?
Hello krnetadragan
Connect the device to another computer to see if the issue actually comes from it or from your machine .
If your drive is defective , try a recovery tool from http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
You can also open the box ( will be lost ) and connect the drive straight inside your pc if it is a desktop .
If the drive runs fine with the other computer , try changing the usb connection on your pc .
Try also a system restore and set your computer back to a date when your device was running fine . Back up your latest data first .
Best regards .
fanaudi
Mar 16, 2011 | Maxell 665202 - HD500 500 GB - USB - 2.5 -...
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My simpletech 500g hdd wont work and i took it to staples and they couldnt retrieve my files . please help
Does the hard drive get recognized by the computer? Your best bet and probably only bet would be to remove the hard drive inside from the external casing and plug it directly into a computer and see if you can retrieve any thing that way. One good program I know of is file scavenger. But the drive has to be working enough to actually work on a computer. Beyond that you would have to send it to a professional that deals with data recovery. I ALWAYS recommend that any important files be backed up. This means the files are saved in two different spots. So if one is lost or stops working you have the back up to use. Hence the name back up. If you need any further assistance let me know.
Thanks,
Lee
Feb 25, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I have an Iomega GDHDU 2 external HD - 1TB. Just got it today, and when I plug it in it crashes XP (XP - SP2, 1.66GHz, 0.99 GB RAM, Del Inspiron Laptop 1420). I don't get the big blue screen, I get a...
Dell has stated in Dell knowledge base document FA1021802, that a USB device (such as a external hard drives, scanner, printer, etc) may not be detected or function correctly when connected to the USB port of a Dell Latitude or Inspiron PC (it may occur on other models as well).
Various communication errors may occur, including device initialization and device not found errors.
Some Dell computers do not provide enough voltage from the USB ports to power some USB devices.
Dell recommends purchasing a powered USB hub to provide the USB devices with enough power to operate correctly.
I think this explains it. Thank you and good luck!
Nov 01, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Model GDHDU Iomega external usb drive It's been...
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
May 20, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I just purchased my external hard drive back in mid january and a week ago it stop working.Model # GDHDU Serial # THBK423461 or either TRK423461 sorry the second and third letter its hard to read. my hard...
jfmartinezmx
It is possible that another device grabbed the drive letter that was assigned to your external drive. The links below will help you resign a drive letter if needed.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive is not showing up in Disk Management then this is a sign that there is a problem with the drive. I would recommend connecting it to another computer to see if it will detect. If it does not then there is a problem with the drive and I would contact the manufacture of the drive do see if you are still in warranty.
Let me know if you have any more problems or quesitons
Issken
http://www.fixya.com/users/issken
Apr 29, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 34579 1 TB USB 20 Hard Drive Logo
935 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
