Question about Whirlpool Washing Machines
I have a Whirlpool duet ht washer. It is giving me an F22 error. How do I fix it?
    Brigadier General:
  • 6,277 Answers
Whirlpool 'F22' decodes as 'control unit failure' which unfortunately is not normally something which could be fixed by the user.
I fear the only answer is to call for repair, sorry ;-0(
Good luck,
John C
Posted on Apr 07, 2011
How do i fix a F02 error for a whirlpool duet ht
Take the service panel off and look for the tech sheet behind it. It give explanation of error and remedy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 29, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport washer is giving a F-28 error message. What is wrong?
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam F22 error code
it needs a servicing as .the parts are getting blocked and not able to move frequently.
also check for the motor.
also try to clean it externally and see it should work.
and if not then calling a tech is advisable.
check out this link for more help
http://www.applianceaid.com/washers.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
457 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
