There is a filter in the tank on the end of the oil pick up pipe, if you have checked the gear you must have already removed the cluch and sprocket, if you now remove the two screws holding the pump and take it away, behind here is the pick up pipe, pull it out with long nose pliers and inspect the filter, the later machine has an up graded pick up and delivery tube in one to stop any leakage, if you have a seperate delivery and pick up pipe i would suggest changing to the later pipe part no. 545037101, if this still does not help it will have to be a new pump part no. 530014410.
