Question about LG LMN090HE Split System Air Conditioner
I have an LG lmu180HE split system that I am ready to install. It came with no wiring diagrams. What gauge wire do I need to run from the outdoor unit to the indoor units? Do the indoor units also require a separate power feed? If so, where are the connections located on the indoor unit (lmn090he)?
Replacing (B) comp. and need to charge system, noticed no high side service port to weigh in charge.
Posted on Aug 09, 2011
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Installed LG split system. The unit does not
Any chance that you've got L1 and L2 hooked up to the same leg of the main? That would still give you 120 on each but not 240 from L1 to L2 like it should be. I'm not familiar with the LG system, but I would think that a comm line would have two wires.
Jul 14, 2010 | LG Art Cool LA181CNW Split System Air...
I need the wiring diagram for an outdoor split system condensor unit mine caught on fire and i cant see the diagram on back of panel
image11.gif I've been trying to copy and paste a typical AC wiring diagram, but for some reason I am unable to thru this sight. Maybe if you post your email address I can email it to you.
May 18, 2009 | Dayton Split Condensing Unit Air...
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Dec 09, 2007 | LG LSC183VMA Split System Air Conditioner
LG LMN090HE Split System Air Conditioner Logo
440 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
