Question about Philips Avent Scd520 Dect Baby Monitor
Hello need to replace the parent unit battery from my Philips Avent Scd520 Dect Baby Monitor. Where can I buy a new one in Toronto?
  • 22 Answers
This is not a solution. :(
In Toronto, or indeed anywhere!? I am with you, Pao, the silly parent unit battery (which is a simple wiring case around 2 AAA batteries) can't be purchased anywhere, as far as I can tell. Yet it's so simple, it must be identical to something else out there.
If I find out what, I'll post it here.
eastpole
Posted on Jul 12, 2011
I need a replacement battery pack for Avent 420303584800 Battery Nimh Scd510 520 AND CANNOT FIND IT. aNY sUGGESTIONS?
The battery details are a 700mAh, 2.4v, Type Ni-MH. some model number are BY1146, CRP395/CRP395/01.You should be able to pick these up through ebay easily.
Jan 23, 2014 | Philips Avent® Scd510 Dect Baby Monitor
I have a problem with the parent unit (model SCD510). It is charged, the leds are green and after a few seconds, I cannot hear anything. When I press the sensitivity button, it works again for a few second...
Hi mcazanaru,
If you haven't yet contacted Customer Support, I would suggest speaking directly with an agent to diagnose and troubleshoot your issue.
Customer Support
1-800-542-8368
Product Support Site
http://ow.ly/6sn5I
Hope this helps!
Sep 12, 2011 | Philips Avent® Scd510 Dect Baby Monitor
I have Philips AVENT DECT baby monitor , the problem is the screen of the parent item was broken i can't see anything but we can hear and talk from it How can i fix the screen again ? Thanks in...
Hi ghadah83,
Doesn't appear there is a fix for a 'broken screen,' however, you may want to visit the Philips Support Site to look further into your issue:
http://ow.ly/5XZI7
You can also reach Consumer Care by calling 1-800-542-8368. Below is an FAQ that might help, too.
Question
Why does my parent unit not turn on when I place it on the charging base? Answer
Your battery may be flat. It may take up to 1 hour before you can use your baby monitor again. If this happens, we recommend that you fully recharge your battery before use.
Hope this helps. Let me know by rating this solution. Thanks!
Aug 07, 2011 | Philips AVENT DECT Baby Monitor...
What size is the bolt and thread size needed for the tripod mount on the Canon G12 digital camera?
Hi Winterhawk.
I think you'll find all camera tripod mount stuff is termed 1/4-20. That's 0.25 inches diameter, 20 threads per inch.
Obviously you want to make your bolt short so you don't crack the camera case, strip the bolt, or otherwise get into trouble.
See also:
http://en.wikipedia.org/wiki/Tripod_%28photography%29
Cheers and enjoy your project,
eastpole
Jul 12, 2011 | Philips Avent Scd520 Dect Baby Monitor
Where can i buy a replacement battery for the philips avent baby monitor?
My wife and I have the same monitor in the picture on this FixYa site. The battery pack is basically two AAA nickel metal hydride rechargeable batteries. Remove the old battery pack. Cut the paper that binds the batteries and plastic pieces in place. We bought a pack of rechargeable batteries at Radio Shack. I cut a piece of metal coat hanger about 2/3" long. I then bent it in half forming a squashed U. I placed the piece of hanger in the "top" (w/o holes) piece of plastic and placed the new batteries in the plastic piece (realize that the RH battery needs to have "+" down and the LH battery (-) down). I also slid the bottom piece onto the batteries too. I used some electrical tap to hold the batteries and plastic pieces together (wrapped around the assembly). Snap it in...it will fit slightly tighter than the original, but will work just fine. One could possibly forgo the hanger piece and maybe use some aluminum foil. I figured the coat hanger is a better conductor.
Apr 07, 2011 | Philips Avent Basic Baby Monitor w/ DECT...
Trying to purchase a replacement parent handset for SCD520?
You can't. I just called Philips and apparently if the parent monitor stops working for whatever reason after the warranty has expired, there is no way to send them off to be repaired and no way to purchase a separate parent model. You are STUCK with buying the whole package again. I have a perfectly good base, but the parent model got into the hands of the child and no longer works. The parent units have to be sold with the base. These parent units are so vulnerable; can't believe there is no way to purchase a replacement. No happy with Philips.
Feb 05, 2011 | Philips Avent Scd520 Dect Baby Monitor
1- The baby unit doesn't work on the mains only 2- The parent unit is on the charger for a day now and still doesn't open
Your issue #1 seems like a power adapter issue. Please swap the sender and receiver adapter and see if anything changes. Mark them with a sticker or felt pen before you do this because they probably are identical.
Your issue #2 seems like you have defective batteries, although I don't understand 'doesn't open'. The receiver uses standard NiMH cells that can be reached through the back battery compartment. You could swap them out and test.
If the set is still within warranty I suggest you take it back. Within the warranty period you usually get a replacement.
I hop this helps.
With kind regards,
Babycare.nl
Erwin de Raad
Sep 16, 2010 | Philips Avent® Scd510 Dect Baby Monitor
Battery in parents monitor won't hold a battery charge. worked for 18 months now just beeps constantly or just turns off.
We had the same exact problem, tried replacing the rechargeable batteries but to no effect. We called Phillips directly and they were very nice and are shipping us a replacement unit (they discontinued this model and I suspect this is a known issue).
Sep 05, 2010 | Philips Avent® Scd510 Dect Baby Monitor
Philips Avent SCD520 Baby monitor interference
cold be intefernce from any other electronic device... potentially at a neighbours. even though mifddle of the night, could be microwave, kettle, electric blanmket, heaitng system, etc etc ... any appliance. If on the 2.4ghz wavelength could also be a computer wireless network nearby? good luck with finding and isolating - worst case, take it back and get one on the 1.8ghz ... which is reserved for these devices, and cordless phones, etc
Aug 30, 2009 | Philips Avent Scd520 Dect Baby Monitor
Philips Avent Scd520 Dect Baby Monitor Logo
595 people viewed this question
Top Philips Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Philips Baby Gear Expert? Answer questions, earn points and help others
