Question about GE Dishwashers
My dishwasher is going through all the cycles but is not draining the water.
  • 744 Answers
You didn't specify the make or model, but see this link for information about general problems with a dishwasher that won't drain:
http://www.ehow.com/search.html?q=dishwasher+doesn%27t+drain&skin=corporate
Posted on Apr 07, 2011
Water does not drain at end of cycle
Could be drain pump , float switch, or PCB. Does it initially go thru a drain cycle when you start a cycle? Is there water in the bottom of the tub?
Oct 02, 2013 | Bosch 24" Built-In Dishwasher - SHE43R55UC...
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
Dishwasher did not drain all the water - water sitting in bottom of dishwasher
start and cancel cycle to drain the water out and check the position of your drain hose.....water is probably backwashing into the d/w, hose should leave the drain and go up to the height of the d/w
Jun 10, 2009 | Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Standing water in my kenmore dishwasher after complete cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Rinse cycle
is the drain from the dishwasher in a syphon or runs into a free drain that air can break siphon cycle
or is drain up high enough eg 600 off floor be fore going into drain if not water will run in then straight out
Feb 23, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Dishwashers Logo
57 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
