Question about HP Computers & Internet
How to clean the fan and cooling module of hp probook 4410s? [ it gets too much heated, but doesn't shut down. its happening for no longer than just 2 weeks, before it was never so hot .i removed the keypad and could see dusts clogging the fan. but i could not remove the fan and cooling module.]
    Sergeant:
    Champion:
  • 286 Answers
O k 1st you can buy small computer fan vacuum machines that will **** all of that dust out. Then you must use a Laptop stand to let air run and circulate under and around the computer.
Hope this helped
Posted on Apr 07, 2011
  • 53 Answers
Go to a local computer shop or big box store (staples, best buy, etc) and pick up a can of compressed gas. These are labeled under multiple different names. The one I have here is labeled power duster. Take this and your laptop outside in good weather conditions (not raining, snowing, windy) and then everywhere you see dust hit it with the compressed gas. You want to do this outside as its not compressed air but an actual gas. Just a heads up the can gets VERY cold and the longer you use it the colder it gets. Take frequent brakes so you don't start spraying an actual liquid gas. Always spray with the can right side up. If you turn it upside down there is a higher chance of shooting out a liquid instead of a gas.
Put your computer back together and it should operate much cooler.
Testimonial: "thanks.......... alot ! i am looking for this product in my country, bangladesh, where it assumes to be rarely available. thanks for sugg though. "
Laptop shutting down with 50% battery back up
Check power plan settings. Also it can be overheating not because of battery !
Apr 17, 2013 | HP Computers & Internet
My hp probook 4410s laptop is switching off suddenly in half an hour if it is hot. what is the problem?
it's hot, that's the problem, get a cooling pad, and/or spray it out with compressed air. it's always possible that you may need to take the back off and clean out the fan.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 12, 2012 | HEWLETT-PACKARD Computers & Internet
I bought my hp probook i month earlier. now it gets over heated and shuts downs.its cooling fan doesnot work?what should i do?
Don't try to fix it yourself, otherwise you will void the warranty. Just take it to an HP dealer and they will fix it for you, for free.
Jul 17, 2011 | HP ProBook 4510s Notebook
I have HP Probook 4510S since a year.In summer season it gets over heat and suddenly shut down.Even while its on plane surface... it works fine while its in my LAP
The feet may have popped off the bottom, where the vents are located. Either replace the small feet (they just stick on) or set the laptop on a cooling stand so that the bottom is exposed to the air. You may also want to clean the vents.
Please remember to vote for me if you like my solution.
Apr 07, 2011 | HP ProBook 4510s Notebook
How to disassemble an hp probook 4410s?
Welcome to Fixya. If you want to disassembel the HP ProBook 4410s you can use the link below. It shows how to remove the parts of the notebook.
HP ProBook 4410s Parts Replacement Guide
If you have questions please let me know. Thanks for using Fixya.
Apr 07, 2011 | HP ProBook 4710s Notebook
Where is the logo of wi-fi in hp probook 4410s........ how to enable or disable it........
On some HP laptops there is a smooth illuminated strip that you think is just lights but it's actually touch sensitive. there could be a WiFi symbol there which you should touch to turn it on.
On others it's a fn key over the F12 key.
May 21, 2010 | Computers & Internet
Laptop switched off while i was working on it
After the notebook shuts down do not turn it back on for 15 minutes and then test it again. Will the notebook work longer if you let it cool down for a while? Isn’t it hot if you touch the bottom? Can you hear the fan running?
Most likely you experience a laptop overheating problem and it would be fixed by cleaning the cooling module – the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on. The cooling module helps to keep the CPU cool when the laptop is working. The cooling module includes two parts: the heat sink and the cooling fan. The heat sink is attached to the CPU and helps to conduct the heat from the processor to the radiator. The cooling fan blows on the radiator and helps to disperse the heat produced by the CPU. The laptop will overheat if the heat sink radiator is clogged with lint and dust or if the cooling fan stopped spinning.
If your laptop shuts down after some time without any reason and warning, check if the cooling fan spins. Usually it makes some noise and you can hear it. If the fan works fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air, just blow inside the fan openings on the laptop bottom. If the heatsink is completely clogged, then it is necessary to remove the heatsink for cleaning.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!  uva
Mar 25, 2009 | Gateway 830GM PC Desktop
Computers & Internet Logo
846 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
