Question about Garden
My husband has a Troy-Bilt LTX-2146 Lawn Tractor riding lawnmower with a pickup bag on the back. The lawnmower starting puffing white spoke and cut off, so he put gas in it and then had to jump it. Once we jumped it , let it un for a while we cut it off. We then tried to start it again but it wouldn't so we jumped it again but when he tried to put it into gears it wouldn't move. We tried replacing the battery but the mower still won't move forward or backwards. Please Help.
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
I need to replace the blades on my Troy Bilt 46"
If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
Aug 18, 2011 | Troy Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
I have a riding lawnmower. Troy-Bilt Bronco. It
check the battery i.e. load test it they dont last long,most of 2 seasons,then if this is o.k. clean all terminals as any corrosion will cause this also and make sure all connections are tight,it doesn't hurt even if theres no corrosion to loosen and re-tighten all connections
Apr 09, 2010 | Garden
I need to locate the fuel filter for a lawn tractor ltx-1842
Locate the fuel line at the carburetor and trace it backwards toward the fuel tank. You will find a (usually plastic) in-line filter somewhere near the back corner of the engine
Aug 25, 2009 | Garden
Jul 31, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
