Question about Karcher 1850 PSI Electric Pressure Washer Winduction
Althogh the motor is running, the water comes out at very low pressure. The machine is a K4.91
Has it been store in sub zero tempiture if so your pump housing is cracked
Posted on Apr 07, 2011
Our water is low pressure and cold. is there a washing machine available that can use low pressure?
Most old style top load washers use a water level sensor, so the water pressure isn't a big deal for them. And the newer ones are more energy efficient.
Aug 11, 2017 | Washing Machines
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
Water pressure in dishwasher low
Failed pump or clogged lines ?
Jun 25, 2012 | GE GSD2000J Dishwasher
Low presure
sometimes the water pressure from the house is insufficient, when it happened to me it would run weird. The water would come out in spurts because little water would come out of the water hose. You could try and lower the pressure on the machine to compensate for the lack of pressure going in, that's all I can think of.
Jan 21, 2012 | Karcher Garden
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Low or no spray pressure
You sound like you diagnosed it pretty good, so I think you can change the impeller. The biggest problem is making sure everything is lined up so it wont leak after its re-installed. I've never had much luck removing the old impeller without breaking it into pieces. just be careful not to mess up the shaft. If its an older machine, some Whirlpool/Kenmore can have the whole thing changed in one part. Its a little more $$ but it has the motor and all. And its easier and faster!! Also, your pressure problem may be related to the motor.
Mar 15, 2008 | Whirlpool 24 in. DU920PW Built-In...
Karcher 1850 PSI Electric Pressure Washer Winduction Logo
174 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
