Question about Magellan Maestro 3210 GPS Receiver
Does the Maestro 3210 work in the Untied States?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
In answer to your question Yes it does. I have attached a good article about the review of your unit that I am sure you will be interested in reading. The link to the article is below. Either click on the link or copy and paste it in to your web browser. Here is the link:
http://www.magellanmaestro3210.com/
I hope this helps you out if it does please give me a Yes that I did try and help you. Thank you.
Posted on Apr 07, 2011
  • lynda_kelly Apr 07, 2011
    thanks... but I still cannot see where to change to United States
  • Paul Kois Apr 07, 2011
    OK let me rephrase that response, yes it is capable of working in the United States. I am familiar with GPS units but mainly Garmins. With a Garmin you have to have the maps loaded for the US but if your going outside of the US then there are additional maps you have to purchase. I assume on your unit it is capable but you may have to purchase additional maps. I also double checked, your maps are on a SD card which means pop out a card and replace it with a card that has the maps on it you want to use, that is how you switch between the US and another country. Below is a link to purchase additional maps from Magellan. But before you do purchase any new maps I would suggest you contact Magellan Technical support to make sure there wont be a problem I would hate to see you wasting money on maps if you cant use them.
    Below is an additional link to help you out:
    http://www.magellangps.com/Maps/All-Maps...
    But please do contact Magellan first before you purchase any new maps. I hope this helps you out.
Yes you can change it to Canada or USA
How can I update my Magellan Maestro 3210?
  • Hi if you want to update the firmware just login to the website of Magellan and make sure that the GPS must connected when doing the update.
  • For the map update call the customer hotline and check if you can get a free map update or if they have discounts for map update.
  • If you have followup questions don't hesitate to reply to this solution.
Jun 15, 2010 | Magellan Maestro 3210 GPS Receiver
Tip
Could not get this to work with a Magellan Maestro 3210 where the 2008-09 map...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 17, 2009 | Garmin StreetPilot C330 GPS Receiver
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
Mar 30, 2010 | Magellan Maestro 3210 GPS Receiver
How can i update my magellan maestro 3210 without usb cable
i would go www.magellangps.com and download them from the website directly to your computer. Then your gps should have a memory card reader of some sort. You can take your memory card and the updates you downloaded and then you load the updates from the memory card. .
Dec 05, 2009 | Magellan Maestro 3210 GPS Receiver
Switch from true view to map view on the magellan 3250?
You didn't state your model but on my Maestro 3210 and 4210 it's MENU USER OPTIONS MAP OPTIONS
Jan 12, 2009 | Magellan Maestro 3200 GPS
How do I change the country selection on my Magellan GPs system?
I've never crossed the boarder with a GPS unit before but to change countries it's MENU USER OPTIONS REGION I tried to enter a US address but the unit wouldn't take it BUT if you change regions enter lower 48 states then you enter a US address and it will take you there. I just tried it with my 4210 it accepted the address and showed the routing
Jan 07, 2009 | Magellan Maestro 3210 GPS Receiver
How do l update my maestro 3210
you will have to go to magellan.com & order the 2008/2009 map update. it costs a hundred bucks unless you are a caa member, then they knock off 25% or so. You can't burn a copy because they need a special code to make sure you bought it legally. Pretty smart. I just got mine & am trying to get it loaded now.
Good luck
Alex
Nov 12, 2008 | Magellan Maestro 3210 GPS Receiver
Magellan Maestro 3210 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
