Question about Bosch SHU9915UC Dishwasher
The Bosch dishwasher shu 9925 UC/U12 will run through all cycles w/o filling with water. It seems something is telling it it has water when it does not. it has been working fine for a couple years. Water feed is fine and nothing has changed in plumbing to it.
SOURCE: bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Posted on Jan 23, 2008
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: hi, I have a bosch
This appears to address the issue:
http://www.repairclinic.com/0088_9_1.asp#Level1_3
Posted on Jan 19, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
My bosch shu5306uc / u12 doesn't fill with water and it ends up making a growling noise after running - will run forever and never cycle....
DANGER stop using your dishwasher HEALTH CANADA WARNING Health Canada has forced Bosh to recall SHU 53 models. Risk of fire see link below.
http://cpsr-rspc.hc-sc.gc.ca/PR-RP/recall-retrait-eng.jsp?re_id=631&searchstring=&searchcategory=&searchyear=&StartIndex=1&current=true
Dec 22, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 5302 Machine doesn,t fill with water.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 16, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
May 11, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwaher shu 4322 uc/u12
hope this helps
Jan 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9915UC Dishwasher Logo
155 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
