Question about Kenmore Microwave Ovens
Have a Kenmore microwave oven 401.80093700. It will run for 3 to 4 minutes and then some times just turn off. What one or two minutes then it will tell you to rest the clock. Thanks Charlie.
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Posted on Aug 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
garing
  • 998 Answers
SOURCE: Microwave Totally stopped - nothing turns on HELP Needed
check fuse
Posted on Aug 08, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Error Code F-9 Sears Microwave Model 721.64683300
It is not the most straight forward job and can be quite tricky for the uninitiated.
If its under warranty ( but I guess its not looking at the model # , ) return it!
The cost of a magnatron and a board is expensive (It is likely they are both involved in this as there sound like arcing) I would just replace the whole unit. Microwaves are not expensive items these days, but ones own life fiddling with electrics is still quite valuable.
Aug 19, 2009 | Kenmore 62622 Microwave Oven
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Microwave's Power goes off after 3 minutes running..
If the time from START to shut off were EXACTLY 3 minutes, then I would suspect a sensor problem or corrupted code in the microprocesor. But since that time sounds more random, it sounds heat-related, and I would suspect a failing magnetron or a failure in the cooling system. If the cooling fan is not running while the oven is cooking, this failure can occur, and can destroy the magnetron in short order. A cracked magnet (has the oven been dropped?) or other problem can cause a magnetron to go bad and overheat. If it's under warranty, I would definitely contact the manufacturer (see your manual) to find an authorized local servicer. If it's out of warranty, I would balance the cost of a new microwave versus a bench diagnosis fee of $25 or more or an in-shop repair cost of maybe $80 or more.
Oct 15, 2006 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
194 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
