Washing machine vibrates while spinning - Washing Machines
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 07, 2011
Our new Zanussi Lindo300 washing machine moves around quite dramatically when on spin due to vibrations even on 800rpm spin. I have to push machine back into position after washl. Can some one advise.
The load is unbalanced. Try moving heavier or bunched up clothes to a different place in the tub and watch it spin. You may have to rearrange the load slightly to keep the vibrations to a minimum.
Dec 05, 2016 | Zanussi Washing Machines
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
Vibrating only on final spin
no cement is perfectly level so you will need to level it with a spirit level
Jun 11, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Washing machine vibrates really bad during the final spin
make sure your machine is level in both directions
Apr 02, 2009 | Admiral AW22 Top Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
