Question about Microsoft Natural Ergonomic 4000
Keyboard not functioning at all
The keyboard was fine last evening but this morning I cannot key anything on it. The lights on the board are not on at all.
Thanks,
Karen
  • bcarlini Dec 15, 2008
    my ms natural ergonomic 4000 stopped working. its connected to a usb hub. changing it to a different plug does not help. it did for a while then just stopped altogether. any thoughts about this problem? appreciate it.
  • Microsoft Master
  • 5,225 Answers
Since it's a USB keyboard, have you tried plugging it in to a different USB port? If you use a USB to PS2 adapter, check if that is properly seated (both sides). Similarly if it's plugged into a USB hub, try a different port and then plugging it directly into the computer.
I have had USB ports fail and shifting a device to a different port often lets me continue using the device. If none of these ideas help, the keyboard might have a bad cable or other failure that I can't diagnose.
Posted on Aug 06, 2008
  • 21 Answers
The problem may be two things:
1) Its cord is disconnected from the PC unit
2) Your Keyboard drivers are outdated.
If the cord is fine, I recommend that you go to the hardware wizard (Start Menu -> Settings -> Control Panel -> Hardware Wizard) and run a "detect new hardware." This feature should be able to get your keyboard going again - and you should be able to access this feature by using your mouse only.
Keyboard won't type
go to keyboard setting in device manager. check all keys if work properly. u might have your keyboard set to a different format
Oct 22, 2017 | Logitech G15 Gaming Keyboard
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Hi, I have a Sony Vaio VGC LM 18G. Suddenly four keys on the wireless Keyboard no longer register. the keys feel fine they don't feel like they are sticking or that anything is stuck underneath them. I was...
Did you or anyone else spilled anything on them? Do you have a pet that may stepped on your keyboard?
What you can do is to take out on of the problematic keys. Disconnect from power and use a small ruler to pop the key out. See if anything is under there. Maybe hair or food. Do not shake your laptop as this can lead to other problems. Get a dry cloth and clean the key base and underneath the key. Reinsert the key and try it again. If this works do the same for the other keys.
Feb 08, 2010 | Sony VAIO VGP-WKB1 Keyboard
How do I turn on my backlit keyboard on my dell with windows vista?
Sorry for the last answer. The expert probably didn't understand your question.
If you have purchased the optional backlit keyboard, the right-arrow key will have the backlit keyboard icon on it. The backlit keyboard provides visibility in dark environments by illuminating all symbols on the keys. The settings for this keyboard can be personalized by using
Dell QuickSet.
Backlit Keyboard Brightness Settings – Press <Fn> + right-arrow key to toggle between the three lighting states (in the given order).
The three lighting states are:
a. full keyboard/touch pad brightness
b. half keyboard/touch pad brightness
c. no lighting
Hope this helps. If you need the manual for this computer, it is located here:
http://support.dell.com/support/edocs/systems/studio1737/en/SG/F174HA01MR.pdf
Thanks for using FixYa.
Jul 21, 2009 | Dell Studio 1737 Laptop
F2 & F12 keys don't work during bootup w/ Trust KB-2200 Keyboard
It is because of the "Function Key" It needs to be enabled for thenm to work. :))
Apr 11, 2009 | Computers & Internet
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
Compaq v2000 function key not working?
To check system board, connect external keyboard and see if all keys function normally. If the external works OK, check connections on laptop keyboard, making sure contacts are clean and fully seated in the ZIF socket If the external fails to function properly it is the system board. LINK check page 66 of 238
May 08, 2008 | Computers & Internet
Keyboard locked in upper case
Try reseating the key board.
Check whether the keys are stuck especially the shift,alt,caps lock.
Hav you spilled any liquid on the keyboad.
Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
Update the keyboad software from the microsoft website.
Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
You can try holding down function key and press f11.
Control Panel -> Regional and language settings -> Tab: Languages,
Button: Details, and add a US Keyboard.
Check this to know the functions
http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
Check the keyboard settings.
Try using other keyboard to know the keyboard is fine or not.
This will help you i hope.
Good Luck.
Live, Love, Laugh.
May 06, 2008 | Microsoft Windows XP Home Edition
Logitech mx3000 keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Feb 13, 2008 | Logitech MX3000 USB PS/2 Wireless...
Function keys
Have you installed the software which follows with the keyboard? The function keys are usually activated via a software which often follows with the keyboard, probably on the driver CD.
Feb 27, 2007 | Logitech EX100 967499-0403 Keyboard
Microsoft Natural Ergonomic 4000 Logo
133 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
