Question about Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft
Rbc30sbsa part required forpro cut 11stringhead parts required for reel easy string head
2 Suggested Answers
  • 127 Answers
SOURCE: How do you remove the old string head to add replacement?
untwist the nut at the bottom of the spool head to replace the string
Posted on Sep 06, 2009
Black & Decker GH3000. String is stuck on reel.
We live in a townhouse so our yard is't very large. We had actually skipped a few weeks of cutting the grass since our reel mower blades were too dull to cut the thick weeds and grass. This thing got the job done and did't break a cord. Really love Black & Decker tools. More details about the tips and tricks about the Black & Decker Click the link String is stuck on reel
Jun 02, 2018 | Black & Decker Garden
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
How do i replace the starter rope on RY30570
Remove screws holding front and back plastic casing. Remove trimmer shaft with casing. Watch out for spring when you remove the string reel. Best thing is to push the knot out of handel and either cut it or untie it to release all tension on the spring before removing the string reel. The rest is kind of learn as you go.
Aug 11, 2013 | Ryobi 30cc 17" String Trimmer Zrry30530...
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My grasshog will not advance the string and it appears that the center post that the string head fits into has worn out but I cannot imagine why. can you replace that part?
Take your string trimmer reel and throw it in the garbage. Go get a gater head and put it on, it will be the best thing you ever did.
Mar 30, 2010 | Black & Decker 14" Grass Hog Xp...
How do i string a ryobi dual line electric trimmer. i have a dual line trimmer that use to be my dad's (he is no longer living) so i am unable to ask him.
Remove the head, the reel, a knob and a spring will fall out if you arentcareful. Cut about 25 feet of proper size line. Pull 12 or so feet throuth the little hole in the reel and wind the string in the direction indicated on the reel. Leave about 6 inches sticking out on each side. There is a notch on each side to hold the string while you reassemble it. Insert the string into these notches. Reassemble the device and trim away while recalling all sorts of wonderful memories of the times you spent with your dad.
Oct 04, 2009 | Garden
How to remove old string reel from ryobi 105r
After you line up the two triangles, push in and lift. Only the top piece will come off, then the spool is inside. I kept trying to lift the whole head and then the top popped off and I realized what I was doing wrong. It is actually quite easy once you figure out the correct way and where to pull.
Jul 10, 2009 | Garden
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
May 10, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
