Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
My U6616- blew a few parts at once. I have a new push-pull cable --- fine. But the valve arm thing is nuts. I have the new arm piece but for the life of me I can't figure out how that ^*%*^$#$&^( spring goes back in!
  • 436 Answers
I can get you to a parts schematic.
http://www.vacsrus.com/cartgenie/pg_u6607900.asp
Hope it helps
Thanks
Please rate Fixya
Posted on Apr 07, 2011
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum will not pick up dirt. plate in hose stays shut. It has a spring that goes to the plate assemily but will not open. What make it open and close. U6616-900 Hoover Vac Alex
Sounds like you have a valve arm not operating properly. The valve door sould spring open when you lower the handle and will shut when the handle is raised and pushes down on the rear valve arm. See a parts diagram and look at parts 39-41 and 19.
Feb 09, 2010 | Hoover U6616-900 WindTunnel Bagless...
On my hover U6616-900 the self propell work fine on the med setting on med height carpet, but when I go to low height carpet and height set on med the self propell does not pull the vacuum and it is hard...
This is a typical problem you are describing. I would recommend you change the belts, this will resolve the "hard to push" and most likely resove your issues. based on the s/n given you maching was made on sept 2004.
Oct 24, 2009 | Hoover U6616-900 WindTunnel Bagless...
My Hoover Windtunnel, 12-amp, UGG16-900 (or U6616-900 - hard to make out the "G"s from the "6"s) suddenly lost suction this morning. The dirt collection thing is completely clean (I always clean it out...
usually on this machine the door/valve assembly is to blame. if something gets caught in the door/valve assembly it can break this part. you can take it in to see what the est. would be. hope this helps
Jul 27, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover u6616-900 WindTunnel, belts come off system.
in order to seperate the hood from the agitator housing you will need to remove the screws for the bottom plate (4) remove the plate. next you will see (2) screws. one will be by the belt side the other is on the other side by the sucktion inlet. once the screws are off, take a flat head screwdriver and push the tabs (2)on either side of the plastic where the hood meets the agitator housing. once you do this the hood should release itself. hope this helps
Jul 26, 2009 | Hoover U6616-900 WindTunnel Bagless...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Removing the cover from U6445-900
Take off the bottom plate, then there 2 screws on each side(from the bottom)Take the cover for the hose, There is a catch on each side from the bottom edge, use a flat blade and push in, the top will release. The actuator arm just has that e-clip holding it on.
To replace the cable, take off the top handle piece, pull out the old cable. The new one will slip in real easy, then slip the medal piece in the slot before pushing the cable all of the way in. Then attach it to the new actuator arm. This is where you would adjust the cable for forward and backward for the transmission.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Valve actuator, arm & spring assembly
Could not find a picture of this installed, I have replaced this spring and it is hard to do. You have to put the straight prong of the spring unto the valve arm, you will see a spot for it to be at, then wind the other end of the spring around until it goes into a slot, then get it all together on the agi housing before it comes apart. Hope this makes sense.
Feb 15, 2008 | Hoover U6660-900 WindTunnel Bagless...
Self Propelled Feature Has Stopped Working
Does the brush roll turn when it it is on the carpet? The flat belts should be changed often, they stretch and won't turn the brush roll. When you pull back on the handle, does it feel loose or does it feel like you are pulling a cable. It you tilt the handle back, then look down on the right, there is a cable, does it look ok and attached to a nlack plastic part, if not then the actuator is broken. Do the 2 knobs on the nozzle slide back and forth, if not, then the slide may be broken. You may have to take off the top cover and inspect it.
Nov 16, 2006 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
95 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
