Question about Ryobi Garden
No fuel (2 stroke) getting into priming bulb of Ryobi petrol chainsaw 18"
  • Ryobi Master
  • 2,239 Answers
Change the fuel filter in the tank, if this does not help there is dirt in the carb, remove the carb, under the pump diaphram is a filter screen, replce this.
Posted on Apr 07, 2011
Petrol/2 stroke oil mixture for. RYOBI chainsaw CS3635
normally around 40-1 will work . Many dealers now are recommending buying the premixed fuel . to protect your unit from alcohol
Sep 11, 2017 | Ryobi Garden
Why won't my chainsaw prime?
if no gas will enter priming bulb at all I see only a few possible things for this
(1) gas line broken/melted
(2) filter looks good but has internal plug
(3) primer bulb has a small crack in it (most common )
Apr 30, 2015 | Ryobi RCS3535CA Petrol Chainsaw 35cc...
PCN 4545 Chainsaw I unfortunately used unleaded petrol instead of 2 stroke, now can not get saw to start, is it game over for carberette?
Hi, it won't affect the carby which I'm afraid is the only good news. It will need a new piston and probably a cylinder. Depending on the price of these parts to suit your model it may not be worth repairing. Sorry Phil.
Jun 20, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
cheers hope it helps
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carnt keep ryobi pcn 4545 running when i increse the power
How do you increase the power to an electric saw? By your question, I'm assuming a fueled engine model. Check the fuel filter, air filter, and muffler for any plugging. Check condition of fuel lines and tightness of carburetor fasteners. If no help, turn the H jet needle CCW about 1/4 turn--which should result in the engine 4-stroking. Will the engine now run at speed (but not as fast as before)? If ok, warm the engine up, open the throttle and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces best power and least heat! Hope this helps!
Apr 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What type of oil do you put in the reservoir?
is it 2 stroke? if so 2 stoke oil mixed with petrol regards
Feb 03, 2010 | Ryobi Factory Reconditioned 10-Inch 18...
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Nov 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
141 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
