How to connect dual monitors to one pc - Computers & Internet
    Sergeant:
    Champion:
  • 286 Answers
First of all your pc must be the right O/S and secondly you must have 2 VGA ports to be able to use 2 monitors. And vista and win 7 are the only O/S to be able to do this easily. You can always get a VGA splitter. tho. Hope this helps
Posted on Apr 07, 2011
Install both computers withdual monitors
Ok, so the idea of this KVM is to allow two computers which are dual monitor enabled to share one set of dual monitors. This means that PC1 can output to two monitors at once and PC2 can output to two monitors at once, however you only have two monitors.
You should take two cables and plug in both to the dual display output on PC1 (if supported) and then plug them into 'A/B' Computer 1, you should then take two cables and plug them into the dual display output on PC2 (if supported) and plug them into 'A/B' Computer 2.
Now take two cables and plug one into Monitor A and connect this to one of your screens and plug one into Monitor B and plug this into your other screen.
You should see this in the diagram here: http://www.linkskey.com/detail.php?Productid=165
Only one PC can be used at a time.
To support this the back of EACH PC should have a graphics card with two VGA output connections like this:
http://forums.radioreference.com/attachments/computer/25337d1254007019-running-dual-monitors-vdmt090-wb.jpg
Nov 11, 2013 | Linkskey (lkv-dm02sk)
Acer aspire x1200 powers on but doesn't connect to monitor
  • Kindly check the cable that connect between cpu and monitor.
  • Re-insert RAM
  • Input Voltage if not connected using UPS.
Thank you for asking on fixya.com
Mar 20, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
Pilote de controle audio
Dual core computers are capable of powering several monitors. The system requires an software code updates for every disconnection made. For example, a monitor that has an integrated auidio devices causes a condition requiring updates soon as another speaker system has been connected. Acquire the updates at microsoft.com.
Dec 20, 2010 | Maxdata Dual Core 4200+, 1GB, 160GB PC...
How can i add a second monitor or can i add one via bluetooth?
If you can see a DB15 port anywhere on your laptop, you can connect a second monitor to it and change the setting in your display to use dual monitor.
Jul 09, 2010 | Dell Studio One 19 Desktop Computer (Intel...
No video.dual monitor set up. power button briefly goes from amber to green and then off.
after connecting external monitor see on the bar click on the displays symbol the select extended desktop or multiple display then you can see but if no display then restart the computer and go to setup by pressing del key and disable internal monitor and enable external monitor then you can see dual display .windows98 and old versions does not support dual display windowsXP and lates versions support dual display
Mar 12, 2010 | ViewSonic VA1930WM LCD Monitor
Dual monitors occasionally go blank
Check and see if there not in a DPMI mode both on your monitors and the video card under display settings, if your rebooting to get them back on its a DPMI issue that just needs adjustment,
Thanks
Rulds2008
Apr 29, 2009 | Dell Precision T3400 PC Desktop
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
