Question about Health & Beauty
Sigma 8000 says "fix 4".
  • djtimothy May 17, 2012
    http://www.frankshospitalworkshop.com/eq...
    Download this pdf of the service manual and then pg 47 and 48 in section one tells you how to clear it, if it clears you can return it to service. if not, it needs it's ram issue fixed
2 Suggested Answers
facebooktim2
SOURCE: We have a Sigma 8000
manual pdf
http://www.meql.com/Manuals/Sigma-8000-8000-Plus-OPERATORS-MANUAL.pdf
call the company since they don't seperate the Fix# what each means...it's a generic answer
Posted on Feb 08, 2012
We have a Sigma 8000 infusion pump that keeps saying fix 4. We don't have an instruction manual so we are not sure what to do.
You directed this question at me even though I can claim no expertise in this area. FixYa tells me that by my posting this "solution" your question will be made available to other experts, one of whom hopefully will be able to answer your question.
Dec 20, 2011 | Office Equipment & Supplies
Sigma 8000 plus fix 24 error. I know what the error is for but how do you fix it?
Someone pulled out the tubing improperly. First check to see if all the tubing has been removed, and no little pieces have been left behind.
Step 1. Push Options. type code 89 then push enter.
Step 2. (on screen reads Set Bio Options) type code 430 then push enter.
Step 3. (on screen reads Password) type 9250 then push enter.
Step 4. (on screen reads Fix 00 then turns off).
Step 5. Turn on and check for any more errors.
Oct 08, 2011 | Cameras
I need to get a sigma 300mm f2.8 EX APO HSM lens (Nikon mount) fixed. I've already sent it in to Sigma's main referral center (C.R.I.S. in AZ), and they said they couldn't get a part to fix the...
Hi, I strongly doubt you would be able to fix it yourself. My suggestion would be to contact Gus Lazzari he seems to have access to a lot of camera and lens parts no matter how old they are.
Jun 10, 2011 | Sigma Cameras
We have a Sigma 8000 infusion pump that keeps saying fix 24. We don't have an instruction manual so we are not sure what to do.
Hey there!
According to the manual I have here in the lab, 'FIX 24' means that "User has improperly unloaded the set (lever has remained closed)".
Hope that helps!~
Apr 16, 2011 | Health & Beauty
My sigma af 70-300 mm has stopped autofocusing.is there a simple fix or do I need to send it in for repair and about how much will it cost to get it fixed
For you to get this fixed by a lens professional it could cost you anywhere from 60 to 70 dollars but if the auto focus has stopped (and this is not new for these lenses and i have heard stories before) the manufacture will most likely warranty it for no cost to you
Mar 01, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I use a 28 -200mm Sigma Aspherical on my Sony Alpha cameras. it's a decent workhorse but has begun to misbehave and I suspect the autofocus motor is failing. When I attach the lens to the camera and turn...
Unless you're a qualified lens specialist with dust-free laboratory conditions, correct tools, alignment equipment etc, not advisable.
Rather take it in to a pro for assessment and quote.
If you're lucky, they may be able to diagnose the fault and give you a rough quote.
Sounds like internal gearing is worn / loose.
Has lens ever been dropped?
Nov 20, 2017 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
Sep 02, 2010 | Sigma 70-300mm f/4-5.6 DG Lens
Camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Health & Beauty Logo
526 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
