First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustmentsthere click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar skype If you are using skype open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also click start control panel sounds and audio devices audio and also voice it
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s for this device to do this right click on the ? x ! select reinstall driver the drivers might have been corrupted by something or you might have got a virus run your antivrus program as for the sound control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers also control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers hope this helps
if you mean that you cant get any sound on your computer control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers you might have to get a portable usb sound card if you mean dont have a sound card installed hope this helps
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers good luck
you dont need to disable your onboard sound card you may install more than one, if you are using an old sound card without driver just search for the ship driver on it"IC" .
