Tecnhical Error 41
Problem started last week
Paul Philipsz
Paul Marquis
Make sure you have updated your ebay password. Last week they started asking users to reset their passwords because of a cyberattack that compromised a database containing encrypted passwords and other non-financial data.
http://www.cnet.com/news/ebay-hacked-requests-all-users-change-passwords/
Hope that helps!
May 27, 2014 | Computers & Internet
Dear Sir I have a technical error 41 and i dont know what to do.
When did the problem start on the printer
Thanks
proton
Aug 06, 2008 | Brother Office Equipment & Supplies
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
Color cartridge recognition MP160
E5
5 times
The ink cartridges are not installed [1401], or a non-supported ink cartridge is installed [1485], or the ink cartridges are not installed properly [1687].
Check if supported ink tank(s) is installed, and re-install them properly, and then close the scanning unit.
Sep 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hi - I have a Brother printer/fax/photocopier/scanner MFC - purchased about 3 years ago. I can't lift it to find a serial number because my right arm is sprained. But I can tell you it uses "LC 31...
No, I didn't fix it. It says "Error 41. Unplug machine and call Brother." I figure it means it's crapped out. I don't wanna pay to have somebody tell me I need a new one?! Brother oughta be offering Error advice for free to bring folks back as repeat customers. If you have any free advice - it'll earn a future customer! Thanks for your time. Robin
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Error 41 in brother 210c
Error 41 means that the printhead is defectiv! You need a new printhead. Sorry, it cant be fixed anymore.
Oct 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Screen freeze.
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work?
Apr 16, 2007 | Goodmans GPDR40 Digital Media Player
63 people viewed this question
jasbo
jasbo
