Question about HP Office Equipment & Supplies
Bought a inkcatridge refill, done the refill bit, and also cleaned the printhead, but colours arent right, only print in black and pink.
    Sergeant:
    Champion:
  • 286 Answers
What printer make is it.? I bet its HP.
Posted on Apr 07, 2011
Mfc 495cw printer is printing everything pink. I just replaced all the color catridges. how can i fix this?
Try a Nozzel check to see what colours are missing. I would assume that Black, Cyan and Yellow are missing since you are only printing pink. Then do a Printhead Clean to clear the other nozzels.
Dec 19, 2015 | Brother MFC Office Equipment & Supplies
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I have an HP Photosmart D7560 printer. It worked fine until it was left with no cartridges in it for a few weeks. Put in 5 new cartridges and it would only print black. Tried various head cleaning and...
You may need to clean them manually. Take out each cartridge, clean its electronic panel with tissue soaked in a bit of methylated spirit. Also clean the area of contact in the carriage for each cartridge.
If patiently and carefully done all the colours will begin to print; so long as they are still flowing at the nozzle (not dried at the nozzle). To check if they are not dried at the nozzles, apply folded tissue to each cartridge nozzle and press gently, upon removing it, it should come out well/stained with the respective colour. If not you should place in a saucer or plate with a bit of water. Leave for about ten minutes. Then apply the folded tissue again. Ink should blot it well now. If not it means your ink is dried out and you may need to replace that cartridge.
Good luck and God bless!
Nov 13, 2010 | HP Photosmart D7560 InkJet Printer
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
Sep 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
Jan 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Seeker5211
Seeker5211
