Question about Dryers
Lint is on both sides of lint catcher - Dryers
  • Anonymous Dec 02, 2008
    both sides of dryer vent has lint on it.
    Genius:
  • 1,028 Answers
Ck exhaust vent for GOOD air flow be sure hose between dryer and wall is not flattened out bet you have long dry times too
Posted on Aug 07, 2008
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
Is there a way to access the area under the removable lint catcher or should I just use a hanger
I have successfully taken the front of that off and cleaned it out. However, it isn't easy and I could see where it may result in a broken lint catch if not careful. After taking the front panel off - which is a pain in and of itself - you will need to carefully go around the lint catcher and separate it. It is in two halves that are held together by catches all around.
Sep 25, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
BOSCH WTE84100 CONDENSOR DRYER .will not start .Power display on and flashing ,all filter are clean, but machine beeps when try to start.
Two Beeps means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Aug 15, 2011 | Bosch Dryers
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer
TURN POWER OFF First remove 2 srews where your lint filter is located.2 lift the top panel of your dryer to do this use a puddy knife and push on the clips located on both sides between top and cabnet.3 remove rear panel on back of dryer 4remove four or five 1/4 inch nut driver screws on blower housing.5 remove obstruction from blower wheel.
Mar 13, 2010 | Whirlpool LER4634J Electric Dryer
How do you clean the lint catcher
if washer having difficulties draining the water, check out the DRAIN MOTOR PUMP , IT COULD BE CLOGGED with LINT & debris, locate at bottom side is a small motor where 2 hoses are connected , AJ
Nov 22, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Whirlpool dryer lint screen will not slide back into receptacle.
YOU PROBABLY WILL HAVE TO OPEN THIS DRYER UP BY REMOVING THE BACK COVER. ALSO WHERE YOUR LINT FILTER GOES IN AT THERE WILL BE 2 SCREWS UNDER THAT LID TAKE THEM OUT AND PRY THE TOP UP AT THE EDGES ON THE FRONT BETWEEN THE TOP AND FRONT PANELS. THEN REMOVING THE DOOR SWITCH WIRES AND THE 2 SCREWS THAT HOLD THE FRONT PANEL TO THE CABINET AND LIFTING THE FRONT PANEL UP AND OUT. NOTE THE DRUM WILL FALL A COUPLE OF INCHES. NOW YOU CAN UNDO THE DRUM BELT AND REMEMER HOW IT GOES BACK IN. THEN REMOVE THE DRUM. NOW LOOK TO THE RIGHT OF YOUR LINT CATCHER COMPARTEMENT. YOU WILL SEE 2 5/16 HEX HEAD SCREWS, REMOVE THEM. NOW GO TO THE REAR OF THE DRYER AND REMOVE THE SCREWS THAT HOLD THE LINT CATCHER COMPARTMENT TO THE BLOWER HOUSING. NOW GO BACK TO THE FRONT AND SLIGHTLY PULL THE BULKHEAD WHERE YOU PREVIOUSLY REMOVED THE 2 HEX HEADS(ABOUT AN INCH APART) TOWARD YOU WHILE PUSHING THE CATHER COMPARTMENT AWAY TO DISENGAGE IT, AND NOW YOU CAN SLIDE IT OUT AND CLEAN THE GROOVES THAT THE LINT CATCHER SLIDE INTO. REASSEMBLY IS IN REVERSE. iF THIS SCARES YOU TOO MUCH TO DO TRY RUNNING A WIRE CLOTHES HANGER WITH A SLIGHT HOOK IN IT DOWN EACH SIDE OF THE GROOVE TO POSSIBLY CLEAR AWAY THE OBSTRUCTION. SHOULD YOU CHOOSE TO DISASSEMBLE IT, TAKE THE TIME TO VACUUM OUT ALL THE LINT BUILT UP IN THE CABINET, ON THE MOTOR, THE BLOWER WHEEL, AND ANYWHERE ELSE YOU CAN GET A VACUUM HOSE TO FIT OR GO. GOOD LUCK AND I BELIEVE YOU CAN DO IT IF YOU FOLLOW THESE INSTRUCTIONS. P.S DON'T FORGET TO HOOK THE DOOR SWITCH WIRES BACK ON. THAT SEEMS TO BE MY DOWNFALL WHEN WORKING ON DRYERS, AND YES IT MEANS RE-OPEN AND HOOK UP, BUT I'M GETTING BETTER AT IT. :)))
Apr 11, 2009 | Dryers
Dryers Logo
139 people viewed this question
Top Dryers Experts
