Question about Camp Chef Pro 90 GB-90D (NG) Grill
One burner lights the other two do not light.
    Brigadier General:
  • 4,736 Answers
The two faulty burners probably need to be removed and cleaned. Once they are out, you can remove and check the burner orifices to see if they are clogged. Simply use a straight pin the same size as the hole in orifice to clear it out. Be careful not to enlarge the hole. Replace everything in reverse order and test the burners.
Hope this helped you troubleshoot and solve the problem.
Posted on Apr 07, 2011
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Gas burner will not light
will burner light with a lighter "bic".
if you can switch positions with another burner to see if the burner is at fault.
There are also different starters that ignite the burners. If you have 4 of these one could be unhooked or defective.
In the warehouse insects could make a web or cocoon inside the burner. They are easy to clean.
I hope this helps.
Mar 18, 2013 | GE Kitchen Ranges
Burner does not light
The burner is not level ,or you need to adjust the air flow on the end of the burner.
Dec 08, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Mar 01, 2010 | Maytag Ovens
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Ist burner will light, 2nd burner lights only after delay.
You don't say how old it is - could it be that the jet is corroded? They are only a few bucks to replace and are really the only part in your grill that controls how ignition happens.
Aug 20, 2009 | Weber Genesis Silver B Grill
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Camp Chef Pro 90 GB-90D (NG) Grill Logo
89 people viewed this question
Top Camp Chef Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Camp Chef Grilling Expert? Answer questions, earn points and help others
