Question about JVC Video Cameras
I have an AXM17U camcorder that is showing EO3 and wants battery reattached. I have ussed two different batteries @ full charge with the same result..EO3. What's next?
  • bobswensen Apr 15, 2011
    Cleaned tape head, used different tape, different battery, etc. Nothing seems to work...it was working great until the E03 started. Any other avenues???? Thx.
  • 10,319 Answers
1st clean the battery contacts in the camera with a Q tip with solvent applied to the swab
If that doesn't help check the batteries voltage with a volt meter
The charger may not produce enough charge or the batteries are failing to receive a full charge
Posted on Apr 15, 2011
  • 17,970 Answers
E03 Take-up error
Most common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E-04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
1) Remove power source for 1 minute.
2) Reattach power source.
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
Keep us updated.
Posted on Apr 07, 2011
  • ZJ Limited
    ZJ Limited Apr 15, 2011
    Keep in mind that the error E03 can be caused by a SLACK TAPE. Remove the tape and, using the blunt end of a pencil inserted into the sprocket, take up the slack.
    A few more tips:
    1. Don't store the camera with the tape in. Tape is wrapped around a number of spindles and the spinning head of the recording unit inside the camera. If the camera is stored (turned off for more than a few hours) with the tape inside, if there is any condensation, the tape may stick to internal camera components and cause a transport error.
    2. Don't leave the battery on the camera. It will slowly drain over time. This may not contribute to the error, but it also makes sense.
    3. Use either JVC or Panasonic brand tapes, but avoid Maxell and TDK tapes. Panasonic and JVC are not affiliated, by the way. Generally speaking Maxell and TDK are great tape brands, but in the miniaturized world of mini-dv tapes, even very tiny differences in the physical mechanisms of the tape cartridge may add up to incompatibilities or transport problems.
I have a JVC mini DV digital Video camera model No. GR-D295U that was lost for almost 5 years and we found it. The camera had a tape inside and we can see it but the sound like jumps, is anyway that I can...
The battery is very likely BAD (has high internal resistance)! Can you take the battery OUT, and run with ONLY the charge cable attached? Does that make any difference in performance?
May 11, 2017 | JVC GR-D295U Mini DV Digital Camcorder
JVC Everio GZ-MG27U 20GB HDD Camcorder has a problem that it only will work with AC adapter plugged into the camcorder. I have two batteries, one has a full charge of 7.7vdc indicating a FULL charge, the...
Well the first thing I would do is recommend you send your unit in for service as you may end up doing more harm then good. You can call and get free estimates on what this may cost. If you need any further assistance or help locating a service center let me know.
Thanks,
lee
Jul 08, 2008 | JVC Cameras
Shows fault E04 remove & reattach battery
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Apr 23, 2008 | JVC GR-SXM58 Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Error Code EO3 System in Safeguard Mode
Defective mechanism, 03 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 16, 2007 | JVC 580136 Camcorder
Camcorder problems
clean contacts on battery and camera if the battery is charging properly then get a new battery and charge this one and if same resaults then have camcorder repaired check if you have got power using power lead from mains adapter it maybe contacts problem with unit and external power. hope this has helped
Mar 29, 2007 | JVC GR-D350 Mini DV Digital Camcorder
Can't charge the battery
# New batteries need to be drained by using the camcorder until the viewfinder indicates the battery is empty. Follow these steps: Once the battery has been drained, you may use the charger to recharge the battery. # Consult your manual for the amount of time the battery requires on the charger to get a full charge. # A full charge will be delivered by the charger. # Some camcorders have a Refresh feature, which will automatically drain the initial charge on the battery. This allows the battery to fully recharge.
Sep 06, 2005 | RCA CC-432 Camcorder
Video Cameras Logo
63 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
