Question about TallyGenicom 6306 Matrix Printer
I want to print using IBM BPCS but i dont know which printer choose for emulate, Im using a 6306 model.
  • 24 Answers
If you r using Windows Operating system, then use Emulation as Epson fx-1180. If you r using Dos Emulation be IBM Proprinter.
Posted on Apr 07, 2011
Heap over flow error
The "Heap Over Flow" error indicates you are basically running out of memory to store graphics commands before a command to print data is issued.
The solution is
1) Windows Printing.
A) Ensure the printers EMULATION setting matches the printer driver uses.
B) If using the T6050 printer driver ensure you have the correct lavel of firmware. The later version of printer driver need to have the latest T6050 firmware installed in the printer.
C) Consider setting the printer EMULATION to EPSON FX then install the EPSON FX100 driver on the Windows Box
Or
Install the IBM Proprinter XL24 driver on the Windows Box and set the printer EMULATION to IBM Proprinter
Using either of these two compatible drivers will 'side step' issues caused by printer firmware / drinter driver compatibility issues as it may be difficult to obtain suitable firmware or drivers due to the age of this device.
2) If you are coding the escape commands yourself you need to check these as they are incorrect if this error is seen
Oct 24, 2013 | Tally Line Matrix T6050 Printer
The printer is used to print a Bill of Lading on a multipart form. It prints the entire BOL fine except for 1 field on the top/ right side that the invoice number prints in. It will print real small 1...
I would suspect the problem with the field at the top right of the page is being printed incorrectly because the printer receiving an escape command (control code) the printer either does not recognize or performs a wrong function on the 2280+.
If the printer was printing correctly and has suddenly started printing incorrectly it may be best to investigate what has changed ie have any of the following changed;
  • Printer driver or setup on the host computer system
  • Connectivity method
  • Printer settings may have been changed (check the emulation setting)
If the printer is a new setup and has not yet printed this document correctly it may be worth doing the follwing;
  1. If the printer is connected via the parallel interface (either directly to a computer system or via an external print server ) disable Cx-Bid
  2. If you know which driver or type of escape commands are used on the computer system ensure the emulation setting on the printer matches the host system.
  3. If you are not sure of the system setup perhaps try setting IBM for the emulation setting.
  4. If the above actions do not rectify the problem and you are able to select drivers etc on the host system ensure the 2280+ driver (or a compatible Epson or IBM driver is used ie either Epson LQ2550 or IBM ProPrinter XL24)
Further to this it may be nessesary to investigate the data file being recived by the pritner, by performing a hexdump to identify the cause of the problem and also identify a suitable soluion.
Mar 11, 2011 | TallyGenicom 2280 Matrix Printer
How to you know if your new Tallygenicom printer 6312 is compatible to your system?
The answer to this depends very much on what sort of system you are using......
If it is a Windows System you can simply install the Windows Printer Driver and use the printer as a normal Windows Printer.
On Unix / Linux you can set the printer up (usualy using CUPS) in this case you can use one of the standard device types and select a corresponding emulation on the printer-
Set the printer to Epson FX emulation and use a Epson 9 Pin printer driver
Set the printer to IBM Proprinter emulation and use an IBM Proprinter priver (9pin)
On the AS400, iSeries, Seriesi you can also use the Epson FX emulation or IBM Emulation and select the corresponding device type on the host system
Other systems may support similar functionality.
You can also send plane text files to the printer, or alternatively program you own escape commands to control print features.
So like I say it depends on the system you are using, perhaps a good place to start is by contacting Support for the Computer Application or System you are using to see if they support Dot Matrix and or Line Printers.
It is not possable to give a generic "Covers all Systems" answer, unfortunatly
Sep 10, 2010 | TallyGenicom 6312 Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
IBM 6400 Emulation software change
Hello !
I have a IBM 6400 printer in AS 400 system. I want to convert that printer to PC system to print daily to day printing which I can support Window XP and Windows 7.Please let me know the coorrect way to do that and what are the software I need to download.?
Mayuri
May 14, 2009 | IBM 6400-I2S Matrix Printer
OKI ML 280 Elite
You have the Printer emulation set incorrectly. I think it comes as IBM as default and you should try Epson instead. Its a trial and error thing but am sure emulation is incorrect.
Jun 14, 2017 | OKI MICROLINE 280 Elite Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
TallyGenicom 6306 Matrix Printer Logo
99 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
