Question about Clevo MOBINOTE M540SR LAPTOP LCD SCREEN 14.0" WXGA GLOSSY CCFL (SUBSTITUTE PART NO.) (22099281535)
Hi, I would like to update my BIOS in my Notebook, but I did't download the archive. He is a Positivo model Z97 (Brazil), mainboard made by Clevo. Technicals Details Mainboard - Clevo M540SR - VT6363A BIOS - Phoenix Tech - 6.0 - 02/20/2008 CPU: Intel Mobile Core Duo2 T5450 1, 66 Ghz - Merom Thanks ! Almir
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
I need a qflash update for Award Modular BIOS v6.00PG version 42302e31
Hello you can find your mainboard here:
http://www.gigabyte.com/support-downloads/support-downloads.aspx
By entering the mainboard number. (if the mainboard is a gigabyte)
The number is printed in on the mainboard, by the white pci sockets. Just open the case, and look for the number.
When you find the mainboard, select support and download.
Next click on the selection box,to the left, and select bios.
And download the latest bios file.
Good luck
Jul 08, 2012 | Gigabyte Computers & Internet
I want to update bios of Asrock 775i65GV directly from winxp .I don't have floppy drive or bootable usb drive.plz let me know how can i update bios without floppy?
Hi, here is some info:
  1. Download the BIOS package (WinZip format with .zip file extension). And close all programs.
  2. Unzip and save all files to the same directory of any storage location accessible by the host system. And you should see AFUWIN.EXE, UCORESYS.SYS, UCOREVXD and UCOREW64.SYS.
  3. Click AFUwin.exe
  4. It shows a dialog icon to remind you to close other programs. Click "OK".
  5. This will upgrade your bios while the system is running
These link wil show you how:
http://www.asrock.com/support/BIOSUI.asp?cat=Windows3
http://www.asrock.com/feature/InstantFlash/index.asp
http://www.asrock.com/support/BIOSUI.asp?cat=DOS
Here you can download the bios:
http://www.asrock.com/mb/download.asp?Model=775i65GV&o=BIOS
I have to remimd you that: Flashing the bios with a wrong one will make
your mainboard unusefull and it will destroy the mainboard.
You have to be 100% sure its the right one.
Here is a free unzip program:
http://www.7-zip.org/download.html
Just click on the exe file for download.
I wish you the best luck.
Aug 19, 2011 | Asrock 775i65GV Motherboard
Need a bios update
To update the Bios, you have to know exactly the Manufacturer, the mainboard model. You have to go to the Mainboard manufacturer Support Site to download the precise Bos file for the mainboard for the update.
A word of advice, updating the bios is not for the "novice" users. There are many precautions you need to heed before doing a bios update. Any errors during Bios update might render your mainboard useless.
Nov 01, 2010 | Computers & Internet
I want to install a new bios for my memory but I don't find the update, my actually version is the v6.0 (7/19/06). It's a phoenix awards bios please help me :'(
Correction the bios update is for the Mainboard or motherboard for a PC. It not for the "memory"? To update your Bios you have to to know the precisely the model/brand of your mainboard before you can download the new bios file needed for the update from the manufacturer site.
There are precautions you need to heed before doing a bios update for the mainboard. In case of any eventualities or mistakes you made may render the mainboard useless!! If you are not 100% sure how to do it, get some professional help.
If you Mainboard is running ie with no errors!, it is advisable not to do the bios update unless recommended by the OEM manufacturer or you need to run a new function from the mainboard which is not included in the old bios.
Hope this helps.
Oct 05, 2010 | Computers & Internet
I upgrated the processor from a celeron 1.6 to a 1.8 but it is now asking for processor bios update.not sure how to do that
Since you upgraded the processor now it requires BIOS (Basic Input output system) update to get it working correctly... Tell me your computer model number so that i can paste link to download BIOS update for you which you need to download and install to get your computer working !!
Thanks ..
Sep 08, 2009 | IBM NetVista PC Desktop
Want to updat bios for xp
Operating system doesn't have an effect on the bios update process. Simply you can go online and search for your motherboard's website for BIOS flash utility, and new bios files. And through that website, you can follow the instructed steps and update your BIOS. (For example: Asus Mainboard Model P5GD1 Pro -> Go to Asus international website and select your mainboard model, you can find the tools and updates related with your particular model there). You just have to look up for your mainboard's complete brand and model name first.
Apr 14, 2009 | Computers & Internet
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
Mar 29, 2009 | ASUS P4PE-BP Motherboard
Bios update for VIAP4M
Hi there
Go to this support website, select your model motherboard and download the drivers you need:
http://support.octek.com.au/products/mainboards/P4/Intel/mb_p4_i_74.htm
Good luck and thanks for using Fixya
Feb 18, 2009 | VIA P4MA Motherboard
MS8157E BIOS update
http://www.bios-drivers.com/drivers/182/182756.htm
try this. I dont know the date that you have the date info on the card and see if that website works.
Jan 15, 2009 | Matsonic MS8147C+ (N82E16813184008)...
Clevo MOBINOTE M540SR LAPTOP LCD SCREEN 14.0" WXGA GLOSSY CCFL (SUBSTITUTE PART NO.) (22099281535) Logo
209 people viewed this question
Top Clevo Computers & Internet Experts
David Payne
David Payne
Are you a Clevo Computer and Internet Expert? Answer questions, earn points and help others
