Hello, I have one Optonica t.v. model CS5449G bought sometime in 1995. It's working fine until now. But since a few months the picture at times gets faint and suddenly a normal viewing coloured one re-appears again. With each passing day the duration of normalcy restoration has increased considerably i.e. the time duration the picture seen fainter has increased beyond the tolerable limit and its a strain on the eyes to watch the t.v . What could be the solution? For, I do not wish to part with this quality product. Where the fault is genuinely addressed / repaired.
    Habit-Forming:
    New Friend:
  • 35 Answers
Check you model number on bad caps.com
sounds like a bad capacitor
Posted on Apr 25, 2017
tvtek
  • 1284 Answers
SOURCE: coloured sparkles appear in dark areas of picture
Sometimes just adjusting the VSCAN voltage inthe set will cure it. Other times it will be a faulty panel. Either case requires a technician to do the repairs.
Posted on Jun 10, 2008
SOURCE: Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Posted on Aug 11, 2008
the q guy
  • 393 Answers
SOURCE: TV suddenly stopped working; not will not power up at all.
it may have overheated
or it blew a internal fuse
if this is the case you may be covered under warranty. if warranty is expired contact
http://www.tacp.toshiba.com/customersupport/contact.asp
Posted on Apr 29, 2009
  • 157 Answers
SOURCE: Went Dead After 18 Months! Westinghous Model SK-19H210S
your tv has a bad electrolytic cap rather easy to replace it only has 2 legs to unsolder.
location number CE105 its a round can thats swollen at the top.value is 2200 MF at 10 volt replace it with 2200 MF at 16 volt
Posted on Sep 19, 2009
  • 1684 Answers
SOURCE: bought element tv model flx-3711b
The problem you are having is a common and easily repaired one. The problem is caused by a failing power supply board. If you can do a little soldering then you should be able to do the repair. Check out this article on repairing the power supply in this model.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
If you don't want to do the repair yourself we do offer a repair service, you can use the link on that page to request service.
I hope this helps you, if so please rate our solution.
BuddyMc
Posted on Jan 30, 2011
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Bought element tv model flx-3711b in 2008, worked well until about a month ago start having problems, it start taking longer time to come on, sometimes picture comes on but no sound and sometime loud sound...
BuddyMc
Jan 11, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I have Optonica TV , Model # CS 5122.....Bought it somewhere around in 1987 or 88.....faced no problem till now.....But since a couple of days the picture on the screen is not clear & is even blinking...
I have optonica TV model CS5145A brought from mumbai in 1993. But since a couple of months TV automatically trips when I increase the contrast and decrease the brightness and the picture on the screen is not clear ..So can u suggest me which component has to be replaced?. Already i replaced the SMPS and power resister in power supply circuit.
George, Hubli, karnataka Email - georgekj_swr@yahoo.co.in
Sep 02, 2010 | Televison & Video
After a few minutes the picture goes haywire and a loud high freq
Hello
This is a warranty issue. Either take the TV back to SAM's club or call Vizio for a warranty repair.
Jul 28, 2009 | Vizio L32 32 in. LCD HDTV
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Hello There!, Where can I get a T.V. Picture tube for my Sharp Optonica CS 5400 Model TV ?? (Near Goa or Bangalore)
You could try KOTHARI ELECTRONIC HOUSE 75, Sadar Patrappa Road,, Bangalore - 560002 (Karnataka) India Phone(s) : 080-2223351 Should cost around Rs.2500-3000. But, as the model you are mentioning is pretty old, is it worth replacing a Picture Tube? Think about it
Jun 08, 2009 | Sharp Televison & Video
My 1995 mustang stalls after turning on A/C
Sounds like the air conditioning pump is seizing up. You should get it checked out.
Apr 25, 2009 | 1994 Ford Mustang
LG 37 inch Flat Panel Loses picture
Take a camcorder and capture it, that should be enough proof that it's failing often enough to be repair right. When the picture goes out, can you see it dimly if you take a flash light to the screen? It might be a bad inverter.
Apr 25, 2008 | Televison & Video
Black-out
Sent it back under warranty- this has an internal fault.
Aug 06, 2007 | Kodak EasyShare C533 Digital Camera
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
