Question about MSI KM4M-L Motherboard
What's the correct jumper for jbat1 sw1 sw2, i think i've screwd their correct jumper
  • 41 Answers
Sw1 should hook to PWR, the first two horizontal pins in the back row, with the text on the connector facing you, sw2 should hook to RESET, the next two horizontal pins in the back row. You will probably want to hook jbat1 to the HDD indicator, which are the first two horizontal pins on the front row, facing you. All of these should go in the first block of pins.
Please remember to vote for me if you like my solution.
Posted on Apr 07, 2011
I'm upgardeing my ms-7061's cpu from a 1.5 to 2.2
http://www.msi.com/product/mb/KM4M-V.html#/?div=Detail
Download > Manual >
CPU
Supports AMD Athlon / Athlon XP / Duran (Socket 462) processor.
(Socket 462 = Socket A)
Supports from 1100MHz to 3000+ model.
VIA KM266 Pro motherboard chipset - Front Side Bus support of 266MegaHertz.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
(Same specs as a VIA KT266A but with Integrated Graphics.
The 133MHz FSB support shown is doubled. AMD processors are 'Double-pumped')
VIA KM400 motherboard chipset -
FSB support of 266MHz to 333MHz.
(Same as KT400 but with Integrated Graphics)
VIA KM400A motherboard chipset -
FSB support of either 266MHz, 333MHz, or 400MHz
(Same as KT400A but with Integrated Graphics)
Looking at the Bottom/Right corner at the CMOS battery;
There are THREE sets of jumper pins to the bottom right edge of the CMOS battery.
6 pins towards the outside edge of the motherboard, 3 pins to the inside of the motherboard. (Left side of the 6 pins)
On the 6 pins in a row configuration, the top 3 pins is SW1.
The bottom 3 pins is SW2.
The 3 pins to the inside of them is JBAT 1
In the 3 pins for SW1 the bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Same for SW2. The bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Jumper on pins;
SW1 pins 2 and 3, SW2 pins 1 and 2 = 266MHz FSB support
SW1 pins 1 and 2, SW2 pins 1 and 2 = 333MHz FSB support
For the KM400A (KT400A) motherboard chipset;
SW1 pins 1 and 2, SW2 pins 2 and 3 = 200MHz FSB support
1) What is the model name, and model number of the AMD processor you are going to use?
2) What kind of Thermal Paste are you using?
3) What are you using to clean the bottom of the Heatsink with, and is the top of the Processor clean?
4) Are you following Anti-Static Precautions?
Post back in a Comment.
Regards,
joecoolvette
Oct 13, 2012 | Computers & Internet
Schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Nov 09, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
How do i wire in a 2 light colour signal to a 2 way switch
Two Way Light Switch Wiring Have you ever wonder how a lamp that is used to light up the stairs of a building is connected to the two switches that controls it from either end? These two way switches have a single pole double throw (SPDT) configuration. Each has a common terminal (COM) with a pole that can be switched between position L1 or L2. The two way light switch wiring can be implemented by using 2 different methods. Both of the methods used are described below.
The first method as shown in the figure above have the COM, L1 and L2 of both the SPDT switches connected together. For incandescent lamp, the recommended wire gauge used is AWG #18. The LIVE AC Source is connected to L1 of SW1 and one side of the load is connected to L2 of SW2. The other side of the load is then connected to NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is at ON position and the other is at OFF position. If both switches are in the same position, the lamp will be OFF.
The other method is as shown in the figure above. In this configuration, the L1 of both SW1 and SW2 are connected together. Similarly, the L2 of both SW1 and SW2 are connected together. The LIVE of the AC Source is connected to COM of SW1 and one side of the load is connected to COM of SW2. The other side of the load is then connected to the NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is ON and the other is also ON. If both switches are in different position, the lamp will be OFF.
Take note that as the installation involves mains power supply, only those who are qualified and have electrical wiring knowledge should do this wiring. When doing the wiring, it is recommended that the power supply is disconnected from the load and the switches.
Nov 13, 2010 | Computers & Internet
DOES ENGINE HAVE TO BE REMOVED TO REPLACE CLUTCH. HOW DO I ID CAR AS A SW1 VS SW2?
Trans has to be either removed or unbolted & moved away from engine 3" or more to gain access to clutch assy.If you remove trans all the way Cradle needs to be removed & engine supported with special tool.Big Job On the ground!!
May 05, 2009 | Saturn SW Cars & Trucks
1993 Saturn SW styles
SW1 is a single overhead cam. SW2 is a dual overhead cam both have multi port injection.
Dec 16, 2008 | 1993 Saturn SW1
I'm wondering about 1993 Saturn station wagons. One website describes two models, the sw1 and the sw2. Another distinguishes two fuel injection types for that year's wagons, mfi and tbi. Do they...
mfi = multi port injection
tbi = throttle body injection
the way to tell is look on the intake plenum and see if there is a "carb" sitting there. That's tbi.
Intake plenum with 4 or more fuel lines going to each cylinder is a "MPI" (multiport) system....accordianman
Two way lighting switches
This switch system is not wired correctly which makes me wonder if the "qualified" electrician is actually qualified. Since the system is not working properly, I would first request that the original electrician comeback to fix it at no charge to you. Failing that, get another to trace the problem and fix it. I would get this fixed ASAP as there is the possibility of short circuits and fire if not addressed.
Dan
Oct 01, 2008 | Electrical Supplies
Ibm 61h2500 p/n 61h2471 sw1 and sw2 problem
All sw1 1-4 and sw2 1-8 = OFF, PIII at 133 MHz, SDRAM at 133MHz, and AGP card 2x, not 4x or 8x.
Try it PII and SDRAM 100MHz after.
Jul 22, 2008 | IBM PC 300PL Socket 370 Barebones Kit /...
Boolean Logic
I don't know the syntax but you could easily do this with setting the switches to a constant, then adding them up. The number set would need to be something so that there would only be one solution...the one that you were looking for.
sw1 = 1
sw2 = 2
sw3 = 4
If sw1 and sw2 is both on, but sw3 is off, the number would be 3
If sw2 and sw4 was on, the number would be 6
If all were on, the number would be 7, etc.
May 08, 2008 | Computers & Internet
BIOS not starting
my problem is this my motherboard recently started to not open the computer at all so i take the rams out and put it back in and it works after two days from shutting down dead silent this process happes almost on weekly basis now one day it just doesn't want to open and i have to leave it for a couple of days and remove the rams and put it back in then it works and two days later stops and so on u get my point ..
one more thing started to happen the dvdrom and cd rom connected to the MB stops working also and i don't no what to do should i change to msi 945 or anyone recommend another type of motherboards or is this fixable? thanks
replay to me on buzzz_forever@yahoo.com much appreciated
Aug 16, 2006 | Intel SuperMicro SUPER Motherboard - 810...
MSI KM4M-L Motherboard Logo
136 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
