Question about Epson Perfection 1240U Flatbed Scanner
I just got an epson 1240u and the platen glass is stained. How do I replace the glass?
  • pjoneill3 Apr 07, 2011
    Worked great. Fixed the problem! Thanks.
    Brigadier General:
  • 3,917 Answers
Hi
Remove the transparency adapter from the top of the scanner and take notice of the two small screws where the adapter was unplugged. Remove the screws with a small Phillips driver, and this is where you must be careful. Lift the rear of the glass frame approximately one inch from its base and firmly push it forward to remove it from the base. There are two plastic hinge retainers at the front of the glass frame that must be shifted forward to free the frame from the base. If the base is lifted to high after the screws are removed these plastic hinges could be damaged. After the glass frame is removed clean it with a water vinegar solution and replace it with the same care with which it was removed.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 07, 2011
My Epson 1240 has just stopped scanning the bottom half of the flatbed. It makes a crunching noise and goes back to the top.
The Track/chain that the scanner bar follows might have some debris/dirt whatever on it stoping it from moving further. Alternatively the motor might have a problem. you can take the cover off and blow that area with a con o' air. Make sure not to get dirt or prints on the scanner or the bottom of the glass
25630969-kdbydlvhgx3mczs4yctz3wk3-5-0.jpg Basic idea of most scanners
Apr 06, 2015 | Epson Perfection 1240U Flatbed Scanner
How to attach loose scanner glass
The glass plate in scanners is almost always held in by some kind of 2 sided adhesive tape AND plastic clips. Th adhesive probably failed, but the glass plate is probably at an angle and not resting on the plastic clips correctly. These act as a failsafe in this very situation, so the glass plate doesn't break or damage the scanner guts.
Anyway, if you want a permanent repair, this is the tape you should use: Amazon com 3M Scotch Heavy Duty Mounting Tape Clear 4010 Double Sided...
It will definitely support the weight of the glass and then some. Be careful with this stuff, it will remove paint (or worse) from drywall. You should only need 4 strips, one for each edge of the glass. Apply it firmly to the glass, then stick the glass onto the plastic bracket.
Apr 13, 2014 | Epson Perfection 1240U Flatbed Scanner
Can't find proper driver for epson 1240U for windows 7 64bit the one on epson website doesn't work on my new HP G62 computer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Downloads&oid=14549&prodoid=54582&category=Products
Copy and paste the link above go there and get your driver.
Bye Ian
Apr 27, 2011 | Epson Perfection 1240U Flatbed Scanner
I lost my driver cd i can 't download it 's configurayion
Log on to support.epson.com to get the drivers for your scanner.
Here is the link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14549&prodoid=54582&infoType=Downloads&platform=Windows&BV_UseBVCookie=yes
Just choose which driver is compatible with your operating system.
May 19, 2009 | Epson Perfection 1240U Flatbed Scanner
How to scan slides on Epson 1240u
Epson have the manuals online
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14549&prodoid=54582
Jan 13, 2009 | Epson Perfection 1240U Flatbed Scanner
Epson scanner 1240U
needle3000:  The Epson "Perfection" 1240U Scanner won't work with Mac OS X 10.4.11 possibly due to the program it is being run from. Like you, I had the same problem: it wasn't being recognized. Epson's drivers installed and ran correctly. Scanner even appeared under Bus in USB Device Tree in System Profile. Finally, I discovered that the Scanner runs if opened directly from EPSON Scan.app under Applications. The problem, in my case, was my ancient version of Photoshop (5.5.) from which I was running it.
 Hope that helps!
Sep 27, 2008 | Epson Perfection 1240U Flatbed Scanner
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
Epson Perfection 1240U Flatbed Scanner Logo
97 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
