Question about Sanyo EM-S5002W Microwave Oven
I think the fuse blew on my sanyo mirowave- it runs but doesnt cook- is this the fuse?
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
After a brief use, my microwave shut off, said end, and after we removed the item inside, the face of the oven went black. We have tried plugging and unplugging the oven into other outlets, but it still...
I say this a lot on here, but may be bad fuse due to bad connections. The fuse holders these companys use are so cheap they get hot if the unit is run for a long time and the fuse Melts at the end, and goes bad. Possibly something shorted out and blew the fuse, But, it had gotten to the point where it said end so it had completed the cook cycle. So, either over heated fuse, or bad door switch that caused it to blow the fuse.. If another switch goes bad or doesnt act like it should, another one is designed to blow the fuse when the foor is opened as a protection feature.
Oct 06, 2017 | Whirlpool MH1140XM Microwave Oven
I currently own a CFMT148GPB2 Frigidaire Pro Series Microwave/fan. It stopped working instantly i.e. was cooking vegetable, it went to the end of its cooking cycle...then 2 minutes later I re-openned the...
I would think the main fuse may have gotten hot due to a bad fuse holder. If the fuse holder gets old and doesn't grab the fuse tightly it is an opposition to current flow, which is a resistance, and any resistance will produce heat, heat will make a fuse melt in its end and go bad. So, either that or something else just shorted out and blew the fuse inside. Need to call a technician. But the fact it finished its cycle then was dead when you went back makes me think the overheated fuse thing.
Aug 23, 2017 | Microwave Ovens
Sharp Carousel Model#4A58: was cooking & made
If you have no power what so ever its probably the main fuse inside the mirowave. You'll have to take it apart. If you try this yourself unplug it then there are several screws around the cabinet of microwave remove them and make sure that they go back where you took them out from because they may or maynot be the same size or length. once you get the cabint off follow the plug wire up into the micro wave there may or may not be a fuse on the wire just inside the frame of the Microwave but it will be close when you find it take it out and replace with the exact size take it to a appliance parts store and get the replacement.
Sep 03, 2009 | Sharp R-4A58 Microwave Oven
My microwave quit working
You have obviously damaged the circuitry. Service is expensive. Unless the unit is under warrantry my advice is to replace the oven. The newer ovens are very reasonable and have great features. Check Home Depot.
Ray
Dec 31, 2008 | Maytag Microwave Ovens
I have a sanyo emc1900 commercial microwave. Yesterday the 10 amp top circuit fuse blew for apparantly no reason, no visible signs of any other damage. I replaced the fuse and the microwave tested fine. It...
It may be a shorted or failing high voltage rectifier diode or high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Sep 13, 2008 | Sanyo Microwave Ovens
Mirowave
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 27, 2008 | Kenmore 80809 Microwave Oven
Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Jul 08, 2007 | Sharp R-408J Microwave Oven
Sanyo EM-S5002W Microwave Oven Logo
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
