Question about Chicago Pneumatic Air Tools & Compressors
I need to purchase a manual for CPC-50 Air Compressor
  • 10,421 Answers
Hi, Bro
Please don't go purchase it.
Just get it free here :
www.cp-gear.com/PDF/CPC%2040-60%20Manual.pdf
Best regards, Jay
Posted on Apr 26, 2011
Well picked this up at a auction and i need to get some part like the air filter and the air filter holder plus a new dip stckalso the manual.. plus i need to know why it won't charge past 50 psi
compressors that do not go past 50 psi generally have a failed poppet valve or reed valve in the heads of the compressor
talk with a compressor repair shop for the filters and housings and where you can get the valves and gaskets
Oct 26, 2015 | Psi Air Tools & Compressors
Why does oil shoot out breather when I turn it on?
If the oil reservoir went dry, this will cause excessive heat and wear on the piston in the compressor. Once you refilled it, air now slips past the overly worn piston and blows oil out of the breather. This escaping air is the reason why the compressor will not get to more than 50 psi. You will need to repair (rebuild), or replace the compressor. Running it out of oil killed it.
Aug 09, 2015 | Campbell Hausfeld HL5402 4-Gallon...
What oil (weight, etc) should be used to fill compressor motor of 5 hp compressor?
Hi William Hunter
That is a very hard question to answer, because they make so many different kinds of oil for compressors.
You failed to mention your manufactures name of the compressor so
I will guide you to the following webpage and you will find your answer there.
Please rate me
Bud
http://compressorparts.com/index.php?route=product/category&path=46&utm_source=adwords&utm_campaign=Compressor+Oil+Generic+Sitelinks&utm_term=compressor+oil&utm_medium=cpc
Oct 27, 2012 | Ingersoll Rand 5 HP Stationary Compressor...
Need manual for Cuisinart
The manual for the Cuisinart CPC-600 6-Qt (5.7L) Electric Pressure Cooker can be downloaded from the following link:
http://www.cuisinart.com/share/pdf/manuals/cpc-600.pdf
This is the commonly available manual for the Cuisinart pressure cooker. Do you have a different model? Can you provide the model number to enable a more detailed search?
Jun 10, 2012 | Cuisinart 6 qt. Pressure Cooker
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
CH 4 ga double stack compressor electrical reset
This is two problems. recycling without use means there's a leak: start er up and spray air connections lightly with window cleaner, watch for bubbles to locate leak. Keep moisture away from any electrical areas. Tighten any loose connections until leaks are no longer present. I have had simular problems. I am assuming that you do not have an oiless compressor. First I changed my oil to full synthetic purchased at the auto parts store. Use the same weight called for by the owners manual. Then I try to always use a 20 amp circuit to run my compressor. I can now run off a 20 amp circuit with a 10 guage 50 foot cord.
Sep 15, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Lost my ec12 manual in a flood out need to replace it
can get manual from where you purchased the unit if purchased new http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC12
here you will find a parts manual
Jul 10, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Open Questions:
Air Tools & Compressors Logo
241 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
