Question about Motorola Mobility MD751 Cordless Phone
Motorola cordless phone says unregistered on the screen. we try to search the base but says unregistered. what should we do?
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
No reception
Sounds like the radio in your base phone has quit working. Yes, you can buy another base but it has to be the same model s your existing one. After you get the new base follow the instruction in your users manual to unregister the old handset and then reregister them to the new base. Link to users manual
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
Jan 29, 2014 | Uniden Cordless Phone
Philips cordless phone se 455
CANON IR2520 ERROR E000000
Nov 11, 2013 | Lands Phones
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
Motorola D210 Cordless Phone
hi i have problem with motorola 210 cordless phone ta base is ok but ta single handset screen shows unregister this why is not working.
Sep 28, 2008 | Lands Phones
Philips CD245 Cordless Twin
just one phone displaying unregistered
Sep 28, 2008 | Philips DECT 2252S Cordless Phone
Binatone veva 1200 cordless phone, UNREGISTER appearing on screen and phone not workindf. Does not seem to be able to register with base.
hi ihave phone binatone veva the phone is not working please can you help me its writing on the screen unregister thanks
Sep 20, 2008 | Lands Phones
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
Jul 30, 2008 | Philips DECT 2252S Cordless Phone
Cordless Phone problem- uanble to use!
Solution:
Unplug base unit
Remove both batteries from the phone(s)
wait 60 seconds
Plug in base unit
Replace batteries in phone(s)
Press speaker icon on base usnit for 5 seconds
Press menu
Select adv adv settings
Select registration
Enter 0000 then press ok
should go from waiting, to searching, then to 'welcome'
press ok...
should be up an running!! :-)
Feb 21, 2008 | Philips CD1503B/17 Phone
Motorola Mobility MD751 Cordless Phone Logo
575 people viewed this question
Top Motorola Mobility Lands Phones Experts
Motorola Mobility
Motorola Mobility
Ngoro
Ngoro
Beth
Beth
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
