Question about Sharp AL-1641CS All-In-One Laser Printer
How to do two sided copies - Sharp AL-1641CS All-In-One Laser Printer
  • Sharp Master
  • 4,338 Answers
Two sided copying... When copying from one-sided originals to two-sided copies, copying orientation can be selected between Turn on Long Edge and Turn on Short Edge...... When making two-sided copies from the document glass, the paper size must be letter...Non-standard size paper cannot be used...When making two-sided copies, the multi-bypass tray cannot be used...... A A... A A... Turn on Long Edge Turn on Short Edge... Select two-sided copy mode.
When copying in a one-sided to two-sided mode:
Use the original to copy key to select the desired one-sided to two-sided
copying mode (Turn on Long Edge or Turn on Short Edge) Using the document glass
1 Press the start key.
The original is scanned into the unit's memory and the number of the
copy quantity blinks in the display.
2 Place the original that you wish to copy onto the rear side of the
paper, and press the start key again.
Copying begins.
Using the SPF
Press the start key. Copying begins in the selected two-sided copy mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Apr 07, 2011
  • 85 Answers
On page 52 and on page 53 of this pdf manual you will find your answer.
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL1641CS_1631.pdf
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
How to copy both side of ID copy card in to one side A5 size pepper
Place the ID in the top portion of the glass, copy side one. Return the paper to the tray, copy side down,
Flip the ID to the other side and position it in the lower portion of the glass, copy side 2.
and there you have it.
Jul 29, 2016 | Toshiba E-Studio 232 estudio232
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
Sep 18, 2015 | HP Office Equipment & Supplies
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
I do not know to copy on both sides of the paper, can you help?
I don't think the HP Officejet 5780 have the capacity automatic for double side copy.
nothing in the printer specification have the double side copy listed.
what you can do is copy one side and trun the paper over and copy the other side.
Dec 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Help with my HP laserjet 2840
The HP2840 is a sigle sided scan device. To copy both sides you must copy one side then load the one sided copies in the tray again and repeat the process again. Pay close attention to which side is printed on and scanned on both the original and copies. Also the top to bottom feed order of the auto doc feeder and paper tray. It's easy to get them out of order and copy first page onto last or worse, both sides onto one side of the copy.
The HP2840 isn't capable of scanning both sides and printing both sides at once.
Hope that helps you. If so hit me with a FIXYA. If not hit my user name and further describe the problem to me so I can help you further.
Aug 20, 2008 | HP LaserJet 2840 Printer
Sharp AL-1641CS All-In-One Laser Printer Logo
426 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
