Question about Brother MFC 7420 All-In-One Laser Printer
The copies from my printer come out faded and washed out but I am not getting any message of low toner. Last night I printed some labels and it has been happening since then.
  • 41 Answers
The print heads may be clogged. Enter the maintenance menu and run the cleaning cycle. If the problem persists you may need to manually clean the nozzles with a Q-Tip and Rubbing Alcohol (Ethyl Alcohol).
Posted on Apr 07, 2011
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Tip
How to troubleshoot the faded printout problem in laser printers?
This is due to this reason:-- A faded print image is normally the result of one of three conditions: The printer is getting low on toner, the print density is set too low, or Econo mode printing is turned on. For the last two settings, a printer self-test (typically a separate button on the printer) will show what the current settings are. If Econo mode is on, and users are complaining about how light the print is, turn it off and/or set the print density higher. If the toner is low, simply removing the cartridge and shaking it to redistribute the toner more evenly can temporarily resolve the problem until you can replace the cartridge. This will help. good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Copier makes faded copies, even though it has toner
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
May 19, 2009 | Toshiba DP5570 Laser Printer
Faded copies
This is usually caused when the toner cartridges are low on toner, or the drum unit needs to be replaced. Try to produce a supplies status page and see what it tells you.
May 07, 2009 | Dell 3100cn Laser Printer
Faded prints about 2" in from the margin
Greetings!
{You used the term "drum". This may indicate a roll type of toner rather than a cartridge style of toner. The following tip is for a cartridge style.}
I get much the same symptom when my HP laser cartridge is running low, and no, it doesn't have a "low toner" indicator either. I get by a little longer with mine, long enough to get out and buy a new one that is, by removing it, holding it over a garbage can at an angle and firmly tapping on it to loosen any compacted toner. I then turn it back horizontally and gently shake it back and forth to evenly distribute the remaining toner through the cartridge and reinsert it into the printer. This usually gets me nice, even prints back and extends the life of the cartridge. I can usually get a few extra weeks out of it by doing this two or three times.
Rob
Jan 14, 2009 | Brother IntelliFAX 4100 Laser Fax
Photo Quality
Check the toner in your printer, It is either low or uneven in the cartridge. Remove the cartridge and gently rock it back and forward. Replace it and check toner levels. You can print a page with this on it fron the menu on the front of the printer.
Oct 16, 2008 | HP Color LaserJet 2600n Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
96 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
