Question about LG Dehumidifiers
Dehumidifier comes on for an instant then goes off and indicates "bucket full". Bypassed switch and it continues to do the same thing.
  • marthaespino Apr 07, 2011
    I followed the instructions you suggested and the same problem continues. The fan comes on for an instant, the light on bucket full comes on and compressor does not even attempt to start. Could the problem be the circuit board. What do you think?
  • 5,370 Answers
If the switch by passed but still the problem is same, that means the problem is with the control board.Its not detecting the bucket.--------- Reconnect the switch as it was and then try this:------ Look inside where the bucket goes in at the top right hand side is the bucket switch. Hold it in and start the unit. If it runs the arm on, the switch must be bent SLIGHTLY until it makes contact with the button and the lite goes out with the bucket in.------- Also check the float in the bucket.If the float in bucket is stuck then it will always detect water as full. and red light will flash.The float moves and actuates the switch.But if float is not moving the switch will not actuate and dehumidifier will not get command that water is empty.But if float is not stuck and its moving freely then its the switch.The switch to which the float actuates.That switch is got faulty.The switch can be manually depressed and checked.If still the red light flashing then switch is confirm faulty.----------- Also check if fan is running or not.Also do you hear any humming.As you mentioned it starts then shuts of, this clears that fan runs.But still re check and confirm it.------------ If the fan hums but does not turn, or turns slowly, the motor needs to be replaced. If the fan won't move, you may have a bad switch . ----------But in your case,you mentioned that fan runs for 2 seconds then shuts down,this indicates that fan switch is not short,its the fan controlling motor,that is got weak and it needs to be replaced.Also check the fan motor connection to main board.If there is a short is wires between fan motor and main board,then this will overheat the motor,as soon as you turn on the dehumidifier ,in that case,if there is short wire the new external wire has to be connected,but if wires look fine then its motor ,that is to be replaced. To replace a bad fan motor, unplug the machine and disconnect the fan wires from the switch panel. You may have to pry apart a plug, use needle-nose pliers to pull the connectors off the switch, or unscrew the connectors.Remove the old motor from its housing, using a Phillips screwdriver or a nut driver and socket.Remove the fan blade from the motor.and in the same way re fit the new replacement motor and connect its connections as it were connected before.---------
If the temperature in the room is lower than the setting on the dehumidifier, the unit will not run a cycle. The unit has a setting of no lower than 65°F. If you have the home thermostat set lower, the unit will not run a humidity control cycle. Set the thermostat higher on the home air unit that supplies the air conditioning. Set the dehumidifier to a lower setting if you are running the air conditioners during the warmer seasons.---------- This will help.Thanks.Helpmech.
Posted on Apr 07, 2011
  • raj somaiya Apr 07, 2011
    Yes very much possible.The control board is causing the problem.Its getting short.It has to be replaced.------ Also try this and see.Disconnect the humidity control , By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off.If the unit functions properly after disconnecting humidity control. that means humidity control rheostat is bad.But if problem is same, that means issue with control board.--------- Also as you mentioned, that compressor will not start but the fan will turn ON.There is a startup relay/ capacitor beside the compressor.If that relay / capacitor gets shorted, then it will not let the compressor to turn on or start.So first check the startup relay/ capacitor.Getting the relay/ capacitor replaced is advisable.Its not very costly part.If replacing relay/ capacitor does not helps.Then go for other troubleshooting.
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
Unit will not run as the "bucket full" switch
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 05, 2011 | Comfort-Aire BHD-501 Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
Light says "bucket full" but
heatman101
May 27, 2011 | Friedrich D65A Dehumidifier
I have a model 54701500 and the bucket full light will not go off. I have bypassed the switch and the light still stays on, any ideas?
heatman101
Feb 24, 2011 | Kenmore 54701 Dehumidifier
When hose is attached, bucket fills up
yes: hose allowed the bucket to be bypassed yes: bucket was there only for the switch to power can you pass a finger through the hole where the hose connected? probably not, right? most of these buckets have a knockout area inside the hose connection. Try prying it out or even drilling it out if required. remember that once you remove hose, you must purchase a plug hose end connector to continue bucket only useage.
Sep 05, 2007 | Whirlpool AD70USR Dehumidifier
Dehumidifiers Logo
60 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
