Question about Trendware TRENDnet TE100-P1U Print Server
I have a Trendnet Print Server TE100-P1U installed. I've upgraded the firmware and it works with one issue. It stops on the last page and hangs up for about a minute then finished the print job. It does this on two computers with XP, but does not do it on one with Windows 7. I've tried several methods of installation. I have it connected to a ASUS N16 router with DHCP and fixed the address as well.
5 Suggested Answers
  • 3 Answers
SOURCE: Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Posted on May 10, 2008
SOURCE: Trendware TRENDnet TE100-P1U Print Server won't
OK, are you doing all this as Administrator? This is a must do.
Are you sure that you have the right IP address?
Can you Ping the unit?
Try another browser to do so, try Firefox, or Google Chrome.
Is your Ethernet cable OK?
Is the Driver a Win 7? if not perhaps you need to set compatibility mode for XP SP2? AND Run as Administrator.
Is UAC set to OFF.
If 64 Bit system has Digital Driver Signing been set to OFF, if the driver isn't digitally signed? (Press F8 at boot up and choose from bottom of list)
Also make sure that you have Disabled DHCP server in ALL PC's, go to Services, and see if it is disabled? It needs to be.
Below is the install how to, have a look at it, see if it's the same as yours?
downloads.trendnet.com/TE100-P1U.../Manual/QIG_TE100-P1U(english).pdf
OK, try this hook directly to the PS, from a PC via, use an standard Ethernet cable, use a direct connection, Do NOT go through the router/ switch, now try setting it all up. Now you should see it connect to the unit,
You should be able to access it, if direct connected, if it still doesn't respond, then the only thing it can now be is a faulty unit?
If OK, once configured then you can hook it up as per diagram, and it should then work.
Posted on Sep 22, 2010
  • 1566 Answers
Is this your first time to encounter this problem?
I fix this problem in Windows 7, run PS-Wizard as administrator.
Posted on Sep 08, 2011
Printing items too long
I would reinstall the printer drivers
Nov 06, 2017 | Trendware TRENDnet TE100-P1U Print Server
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
Trendnet te100 HP P2035 not printing
1. What is the exact error message or error code?
2. Have you made any changes to the computer prior to this issue?
I would suggest you to refer the following Microsoft article and check if it helps.
Printer problems in Windows:
for more help visit CBR Tech Solutions
Apr 17, 2012 | Trendware TRENDnet TE100-P1U Print Server
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
Jun 24, 2010 | Trendware TRENDnet TE100-P11 Print Server...
HP 1018 printer
try this: right click printer, go to tab Ports and check Enable bidirectional support it works for me .
Aug 10, 2008 | Trendware TRENDnet TE100-P1U Print Server
Mar 31, 2008 | Trendware TRENDnet TE100-P1U Print Server
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Mar 05, 2008 | Trendware TRENDnet TE100-P1U Print Server
Printer is offline ever
I would suggest you one option if the operating system is windows. You have to go to Start -->Control Panel --> Printers and Faxes . Then you will see your printer icon there. RIght click on that. Check whether you are having an option "Use printer Online" or "Set printer Online". If you have that option , just click on that and apply the settings and see what happens - Thank you
Oct 25, 2007 | Trendware TRENDnet TE100-P1U Print Server
The 3 LEDs remain green permanently, even when cables are disconnected
Unplug it over night. try it again tomorrow. If it still shows all green its fried. It there a reset button anywhere on it? Try holding it down(if there is) while plugging it in. Keep the reset depressed for 30 seconds or so. Otherwise no bueno. Let me know what happens. Good Luck, Tim
Mar 22, 2007 | Trendware TRENDnet TE100-P1U Print Server
Trendware TRENDnet TE100-P1U Print Server Logo
123 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
