Question about HP Pavilion F1523 15" LCD Monitor
Hp pavilion f1523 How do I lock or unlock the osd, I cant find it on the osd menu I only have a time out option but no lock or unlock option Can you advise
  • 11,361 Answers
Push the MENU button for 10`15 seocnds to lock/unlock the control buttons.
http://www.fixya.com/support/r4460477-hp_vs_15_17_19_f_1705_1905_lock
Posted on Apr 07, 2011
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Osd lockout
press menu then start the power
Mar 20, 2010 | HP Pavilion F1523 15" LCD Monitor
Osd locked message from HP in on for the first time. What is osd and how do I get rid of it?
When the OSD is locked, settings cannot be changed in the OSD menu. To Unlock the OSD, press and hold the MENU button on monitor while the monitor is off, then press the Power button to turn the monitor on. To lock the OSD, repeat the Unlocking procedure.
Mar 17, 2010 | HP W19b LCD Monitor
Osd lockout wont go away. i fix for a short time then it comes back. I am ready tp put my foot throuight this monitor!
Is there a way to set to Factory Default? I can with my NEC, and would think your HP should too.
Oct 25, 2009 | HP Pavilion F1523 15" LCD Monitor
Osd menu keeps popping up
It is the malfunction of the monitor button or circuit pannel responsible for OSD. Get it repaired/replaced.
Regards,
Shrey
Oct 02, 2009 | HP Pavilion F1523 15" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Problem on hp monitor
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir.
Apr 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1523 15" LCD Monitor Logo
241 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
