Question about Philips Avent Basic Baby Monitor w/ DECT Technology
Where can i buy a replacement battery for the philips avent baby monitor?
My wife and I have the same monitor in the picture on this FixYa site. The battery pack is basically two AAA nickel metal hydride rechargeable batteries. Remove the old battery pack. Cut the paper that binds the batteries and plastic pieces in place. We bought a pack of rechargeable batteries at Radio Shack. I cut a piece of metal coat hanger about 2/3" long. I then bent it in half forming a squashed U. I placed the piece of hanger in the "top" (w/o holes) piece of plastic and placed the new batteries in the plastic piece (realize that the RH battery needs to have "+" down and the LH battery (-) down). I also slid the bottom piece onto the batteries too. I used some electrical tap to hold the batteries and plastic pieces together (wrapped around the assembly). Snap it in...it will fit slightly tighter than the original, but will work just fine. One could possibly forgo the hanger piece and maybe use some aluminum foil. I figured the coat hanger is a better conductor.
Posted on Apr 16, 2011
  • gpostal
    gpostal Jan 19, 2012
    Solution worked fine. I used folded aluminum foil and did not tape anything together in case the problem is the charger, that way I can use my regular battery charger and easily just swap out rechargeable AAAs...
  • iramowitz
    iramowitz Feb 13, 2012
    I lost the entire 'rechargeable battery pack' for my AVENT monitor -- but found I didn't need it. Two rechargeable batteries with a simple piece of aluminum foil folded to connect the + and - at the top of the case works perfectly. If you look at the inside of the case you will see polarity (+) indication next to the spring contact. Put one battery in with + contacting the spring, put the second battery in in next to it with its - (negative) in contact with the spring. Use the strip of foil to connect the other ends of the two battery. Everything fits in the case snugly and stays put just fine --- without spending $25.
3 Suggested Answers
  • 12 Answers
SOURCE: Philips Avent SCD520 Baby monitor interference
cold be intefernce from any other electronic device... potentially at a neighbours. even though mifddle of the night, could be microwave, kettle, electric blanmket, heaitng system, etc etc ... any appliance. If on the 2.4ghz wavelength could also be a computer wireless network nearby? good luck with finding and isolating - worst case, take it back and get one on the 1.8ghz ... which is reserved for these devices, and cordless phones, etc
Posted on Sep 01, 2009
eastpole
  • 22 Answers
SOURCE: Hello need to replace the parent unit battery
This is not a solution. :(
In Toronto, or indeed anywhere!? I am with you, Pao, the silly parent unit battery (which is a simple wiring case around 2 AAA batteries) can't be purchased anywhere, as far as I can tell. Yet it's so simple, it must be identical to something else out there.
If I find out what, I'll post it here.
eastpole
Posted on Jul 12, 2011
I need a replacement battery pack for Avent 420303584800 Battery Nimh Scd510 520 AND CANNOT FIND IT. aNY sUGGESTIONS?
The battery details are a 700mAh, 2.4v, Type Ni-MH. some model number are BY1146, CRP395/CRP395/01.You should be able to pick these up through ebay easily.
Jan 23, 2014 | Philips Avent® Scd510 Dect Baby Monitor
Avent baby monitor temperature sensor not working
Hi
Avent is now part of the Philips group ... We recommend you contact them to discuss http://www.philips.co.uk/c/about-philips-avent/19623/cat/
Apr 25, 2012 | Philips Baby Care
I have Philips AVENT DECT baby monitor , the problem is the screen of the parent item was broken i can't see anything but we can hear and talk from it How can i fix the screen again ? Thanks in...
Hi ghadah83,
Doesn't appear there is a fix for a 'broken screen,' however, you may want to visit the Philips Support Site to look further into your issue:
http://ow.ly/5XZI7
You can also reach Consumer Care by calling 1-800-542-8368. Below is an FAQ that might help, too.
Question
Why does my parent unit not turn on when I place it on the charging base? Answer
Your battery may be flat. It may take up to 1 hour before you can use your baby monitor again. If this happens, we recommend that you fully recharge your battery before use.
Hope this helps. Let me know by rating this solution. Thanks!
Aug 07, 2011 | Philips AVENT DECT Baby Monitor...
Hello need to replace the parent unit battery from my Philips Avent Scd520 Dect Baby Monitor. Where can I buy a new one in Toronto?
eastpole
Apr 07, 2011 | Philips Avent Scd520 Dect Baby Monitor
Trying to purchase a replacement parent handset for SCD520?
You can't. I just called Philips and apparently if the parent monitor stops working for whatever reason after the warranty has expired, there is no way to send them off to be repaired and no way to purchase a separate parent model. You are STUCK with buying the whole package again. I have a perfectly good base, but the parent model got into the hands of the child and no longer works. The parent units have to be sold with the base. These parent units are so vulnerable; can't believe there is no way to purchase a replacement. No happy with Philips.
Feb 05, 2011 | Philips Avent Scd520 Dect Baby Monitor
Battery in parents monitor won't hold a battery charge. worked for 18 months now just beeps constantly or just turns off.
We had the same exact problem, tried replacing the rechargeable batteries but to no effect. We called Phillips directly and they were very nice and are shipping us a replacement unit (they discontinued this model and I suspect this is a known issue).
Sep 05, 2010 | Philips Avent® Scd510 Dect Baby Monitor
Philips Avent, fusible broken
The same temperature. Otherwise you lose upper limit protection.
Aug 17, 2017 | Avent Philips iQ Bottle Warmer without...
Aug 30, 2009 | Philips Avent Scd520 Dect Baby Monitor
Philips Avent Basic Baby Monitor w/ DECT Technology Logo
2,492 people viewed this question
Top Philips Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Philips Baby Gear Expert? Answer questions, earn points and help others
