Question about Samsung SyncMaster 740BX Monitor
How do I adjust the tilt function. It seems it is stuck
  • 41 Answers
Tilting on most Monitors is designed to require some force to prevent it from slipping.
Gently yet firmly hold down the base of the monitor on the desk with one hand. Then place a second hand on the bottom of the screen and pull it towards you using even pressure. It will slowly move.
Please also keep in mind that your monitor may not be able to tilt much. If you need it to tilt further, you can buy an alternative stand for it.
Posted on Apr 07, 2011
What do I look for to fix the Power seats and power tilt steering has no power
A control module ! Electronics The steering column has a tilt/telescoping control system that consists of an electronic control module capable of class 2 serial data communication, a steering column power assembly with positioning motor and sensor, and a steering column control switch. The multi-function lever provides for the control of the headlamp high beams, and the windshield washer and wiper.
The tilt/telescoping steering column in/out/up/down switch is an input to the driver position module (DPM). The tilt/telescoping drive motor is an output function of the DPM.
Steering column memory settings are stored in the DPM. The steering column position sensor is an internal part of the tilt/telescoping motor assemblies, and is an input to the DPM. The DPM uses the position sensor input when storing and recalling memory settings.
Same thing with the seats , electronic control module .
Battery positive voltage is supplied at all times to the memory seat module (MSM) through the battery positive voltage circuit from the POWER SEATS circuit breaker located instrument panel (I/P) fuse block. This voltage is used to power up MSM and also to apply power to the seat motors when commanded. Battery positive voltage from the TILT/TELE SW/MEM SEAT MOD fuse located in the body control module (BCM) fuse block that supplies voltage to the seat adjuster switch and the memory function switch, also supplies voltage to the MSM. The MSM monitors this voltage circuit in order to determine if battery voltage is supplied to the seat adjuster switch. The MSM is grounded through the module ground circuit and G301.
Body Control Module (BCM)
RH footwell, mounted to the toe board, behind the carpet
Nov 05, 2015 | 2006 Cadillac XLR
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
How do i adjust the zoom control on the logitech C270 so that i can use the pan and tilt functions?
Do any of you have Follow my face option enabled while trying to use the Pan and Tilt feature? If so, please disable it and try using the Pan and Tilt feature again.
Aug 23, 2014 | Logitech C270 Web Cam
2000 Escalade steering wheel stuck in up position,and won't adjust down, whats the problem?
the release for the tilt mechanisum is made of pot metal and had cracked apart causing this to happen. Any GM dealer can order the tilt housing to repair this
Jun 22, 2011 | 2000 Cadillac Escalade
Tilt steering wheel won't tilt. What's wrong?
your steering wheel adjuster is blocked or stuck up thats why it doesnt freely move to the max. take off cover/ check condition and or lubricate it.
Apr 05, 2010 | 2000 Toyota Camry
Jazzy 1113ATS will power up will allow tilt ajustments but will not move
It may be that the tilt sensor is not working right. Depending on the age of the chair, it will have either a mercury switch sensor that will disable drive when it sense a tilt of more than about 10 degrees, or older ones use two limit switches that are activated when the tilt reaches a certain setting. If one of the switches is stuck, it won't allow the chair to move but the tilt will still function properly. You'll need an experienced tech to test if you don't have the tools or training. Good luck.
Dec 08, 2009 | Pride Mobility Products Jazzy Select 14
My steering wheel is stuck in the down position and wont tilt up in my 1999 mazda millinea
the tilt motor broke i don't think there is way to adjust it manually .
Aug 17, 2009 | 1999 Mazda Millenia
Power tilt in my 97 mazda millenia does not work
the tilt motor broke and it sucks because you can not adjust it manually , mazda sucks big time on Millenia .
Mar 14, 2009 | 1997 Mazda Millenia
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung SyncMaster 740BX  Monitor Logo
335 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
