Hard drive seagate ld25.1 - Televison & Video
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
External hard disk
As you are a seagate user so it would be advisable to try using this software to recover seagate sata hard drive. Just download it online for free trial.
May 22, 2012 | Seagate ST3500418AS 500GB 7200RPM SATA...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
MY PC HARD IS NOT DETECTED
IF THE HARD DRIVE IS IN WARRANTY THEN SEND IT TO SEAGATE FOR WARRANTY CLAIM. TO CHECK THE WARRANTY STATUS GO TO THE SEAGATE WEBSITE. SEAGATE GIVES 5 YEAR WARRANTY.
DONT FORGET TO VOTE
Oct 10, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
500gb seagate reading but not showing in my computer. help
Seagate Drive not being detected:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201713&NewLang=en&Hilite=
If your drive is SATA drive, then you may follow the steps in the below link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SATA_Troubleshooter_-_Serial_ATA_Data_and_Power_Cables&vgnextoid=e4644a3cdde5c010VgnVCM100000dd04090aRCRD
I recommend you to visit the below link that has information on similar hard drive issues in computer:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?SearchOperator=0&ssdFilterCommunity6=0&ssdFilterCommunity7=504
If the drive is not displayed in computer, you may follow the step My internal drive is not displayed in My Computer - 182615 in the above link.
Jun 19, 2009 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
Seagate hard drive
the seagate hard drive is for a desktop, this will not fit a laptop
Mar 24, 2009 | Seagate Medalist 4321 (ST34321A) 4.3 GB...
A larger capacity replacement drive for my st380020a 80gb drive
The IDE version of a 160gb is a:
Seagate Momentus 160GB IDE Laptop Hard Drive
Part Number: 9S1034-506
Model Number: ST9160821A
5400RPM
The SATA version is a:
Seagate Momentus 7200.2 ST9160823AS 2.5-inch 160 GB hard drive
Jan 31, 2008 | Computers & Internet
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
